LS 5th gear in ITR tranny
Old Jan 14, 2008 | 09:30 AM
slvcivic00's Avatar
Default LS 5th gear in ITR tranny
I have an 01 ITR tranny bolted to a stock b18b and want a longer 5th gear for freeway driving. Is it possible to swap in an LS 5th gear for lower RPM's on the freeway? Will it actually drop the RPM's and work?
Old Jan 14, 2008 | 01:35 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: LS 5th gear in ITR tranny (slvcivic00)
Yes, that can be done. Not sure how low it would be on the freeway.
Old Jan 14, 2008 | 05:35 PM
IN VTEC's Avatar
Yes and yes. Cruising rpm will be about 650rpm lower at any given speed for fifth gear.
Old Jan 15, 2008 | 08:54 AM
slvcivic00's Avatar
Default Re: LS 5th gear in ITR tranny (IN VTEC)
Alright, thanks
Old Jan 15, 2008 | 08:48 PM
DC4R27's Avatar
how much does it cost to to an LS 5th gear? i want to do the same thing on my ride.
Old Jan 16, 2008 | 05:19 AM
dyingwish's Avatar
Default Re: LS 5th gear in ITR tranny (DC4R27)
Prices taken from acuraparts247.com
23461-P80-000 LS 5th gear counter-shaft $44.94
23581-P80-000 LS 5th gear main-shaft $71.66
Add the price of shims/sleeves you'll need
Old Jan 16, 2008 | 06:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: LS 5th gear in ITR tranny (dyingwish)
While the tranny is apart I strongly suggest replacing the 5 main sealed bearings that go on the ends of the main and countershafts.
Three of these bearings will need to be pulled off to access the 5th gear anyways, so plan on at the very least doing those. there are two stacked on top of each other at the top/end of the countershaft just under the stake nut, and the other on the end of the mainashaft - 5th gear sits directly below these bearings.
I installed a GS-R 5th gear into my old ITR tranny with ATS 4.929FD to lower the 5th gear cruising back to stock ITR-like ratios.
Old Jan 16, 2008 | 11:13 PM
DC4R27's Avatar
Default Re: LS 5th gear in ITR tranny (B18C5-EH2)
youve got a sweet tranny
Old Jan 17, 2008 | 02:44 PM
CubanoRockr's Avatar
just gotta ask what is your cruising rpm for XXX speed? looking to do a gsr 5th gear with the 4.785 in my ys1 and yea an obx lsd too b/c the ring gear won't fit the factory diff (open anyways)
Old Feb 23, 2008 | 11:57 AM
1dopesi's Avatar
Default Re: LS 5th gear in ITR tranny (CubanoRockr)
good info on ls 5th gear
Old Feb 24, 2008 | 07:56 AM
IN VTEC's Avatar
I have a GS-R 5th with 4.785 final drive.
55mph = 3000rpm
60mph = 3200rpm
65mph = 3500rpm
70mph = 3750rpm
80mph = 4200rpm
Old Feb 24, 2008 | 10:18 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I have a GS-R 5th with 4.785 final drive.
55mph = 3000rpm
60mph = 3200rpm
65mph = 3500rpm
70mph = 3750rpm
80mph = 4200rpm</TD></TR></TABLE>
What wheel/tire size? That means as much as FD ratio.
Old Feb 28, 2008 | 07:51 PM
StorminMatt's Avatar
55mph = 3000rpm
60mph = 3200rpm
65mph = 3500rpm
70mph = 3750rpm
That seems kind of low. With that fifth gear and final drive, you have similar overall gearing to a B16A transmission. And with a B16A transmission, fifth gear revs are quite a bit higher than this.
Old Mar 4, 2008 | 10:56 AM
jdmcivicracer89's Avatar
Default Re: LS 5th gear in ITR tranny (StorminMatt)
so what would i have to buy??? can someone list all the parts that i will need to swap the ls fifth in my b16 tranny. gonna do the swap in a couple weeks
Old Mar 4, 2008 | 06:08 PM
IN VTEC's Avatar
It was always roughly the same no matter what overall wheel size I was using. I'm on 205/50R-15 right now and I use 215/45R-16 in the summer.
I just switched to a LS 5th gear over the weekend, so 5th gear does about 350rpm lower than the GS-R 5th gear I had.
A GS-R 5th with 4.785 final drive gives you a slightly lower overall ratio than a B16 transmission, if you're comparing it to a .875 5th gear ratio. It's close, but not the same. A B16 with a .848 gear ratio would be lower in rpm.
I think I like the GS-R gearing better at this point. I still haven't gotten used to it.
Old Mar 4, 2008 | 07:30 PM
4g hatch's Avatar
i got a cable j1 tranny and im gonna add a 4.9 mfactory final drive and a ls 5th gear. should i only have to replace just the 1 gear and not the gear with the sleeve/synro
Old Apr 3, 2008 | 11:59 AM
spoonfed_DC2's Avatar
Default Re: LS 5th gear in ITR tranny (4g hatch)
is this mod only for the B16 Cable? b/c i have a b16 hyrdo out of a 00 civic si, and looking to do the ls 5th gear but at the sametime would it be the correct gear ratio for a JDM 4.7 final drive? i would also be installing a jdm LSD...
anyone?
i know the 00 si tranny(4.4fd) is pretty close to the (1st, 2nd, and 3rd) JDM ITR gear ratio except for the last 2 gears and the 4.7 fd.
dinthanonh
Transmission & Drivetrain
Apr 19, 2010 05:17 PM
Listerofsmeg
Mar 5, 2010 12:16 AM
imptricer
Apr 28, 2006 09:04 AM
The sweed
May 20, 2003 06:28 PM
