Degreeing camshafts & adjustable cam gears
Old Jan 14, 2008 | 08:30 AM
misterpsycho's Avatar
Default Degreeing camshafts & adjustable cam gears
I've been researching on how to degree camshafts and i have a question... which may or may not be stupid
What's the point of degreeing a cam if you have adjustable cam gears and you play with the cam positioning while tuning??
Old Jan 14, 2008 | 08:41 AM
4g hatch's Avatar
Default Re: Degreeing camshafts & adjustable cam gears (misterpsycho)
its essential to degree cams if you are running agressive cams and/or high domed pistons. all adjusting the gears on the dyno does is to see where it makes the best power. degreeing them is setting them were the manufact. recomends for the best v2v and p2v clearances.
and even to adjust the gears alot on the dyno one should check v2v clearances when the head is off and clay the motor. depending on how radical the setup will determine how much you can adjust the gears
Old Jan 14, 2008 | 09:28 AM
bjones's Avatar
Default Re: Degreeing camshafts & adjustable cam gears (4g hatch)
https://honda-tech.com/zerothread/2003538
this page helped me out alot
Old Jan 14, 2008 | 10:54 AM
hybrid2007's Avatar
Default Re: Degreeing camshafts & adjustable cam gears (bjones)
I don't quite understand this either. As soon as you change the settings of your cam gears on the dyno doesnt that undo the process you went through to degree the cams in?
CBR
Jul 31, 2005 08:51 PM
Nov 11, 2003 01:05 PM
NVBAM
May 21, 2003 09:00 AM
insnimprtguy
Jul 17, 2002 02:11 PM
Got-VTEC
Nov 15, 2001 12:48 PM
