K&N Filter?
Old Jan 13, 2008 | 06:13 PM
dragonle87's Avatar
Default K&N Filter?
Hello I was wondering should I replace my OEM air filter to the K&N air filter w/o the cold air intake stuff just a replacement?
Are there any difference or suggestions out there?
Old Jan 13, 2008 | 07:06 PM
The-Kid's Avatar
Default Re: K&N Filter? (dragonle87)
I liked my K&N stock replacement filter. I say it's worth it. But look around for good prices.
Old Jan 13, 2008 | 07:28 PM
dragonle87's Avatar
Default Re: K&N Filter? (The-Kid)
does the K&N filter mess anything up? cuz i have a friend installed a stock replacement air filter & it messes up his Mass Air Flow Sensor????
Old Jan 13, 2008 | 08:11 PM
TheMuffinMan's Avatar
He knows where you live!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 &raquo;</TD></TR><TR><TD CLASS="quote">does the K&N filter mess anything up? cuz i have a friend installed a stock replacement air filter & it messes up his Mass Air Flow Sensor???? </TD></TR></TABLE>
Your friend fails at the internet.
Personally not worth it.
But a CAI or SRI from like AEM and be done, or get a ghetto ebay one and toss a K&N filter
Old Jan 13, 2008 | 08:21 PM
The-Kid's Avatar
Default Re: K&N Filter? (TheMuffinMan)
It's worth it if you don't feel like getting an aftermarket intake. and still wants to raise some MPGs... stock replacement is good for you. Plus you don't have to waste $$$ on replacement filters.
THE MAF thing is a big hoax. K&N tested this and there was no sign of K&N oil on the MAF. It was covered in silicone from the MAF sensor seal. 90-02 Accords do not have a MAF sensor anyways.
If u want to do it Muffinman's way... The ebay option is great. I got my AEM CAI for my 96 Accord for about $55. Used, but it's in pretty goood condition.
Old Jan 14, 2008 | 05:00 PM
tpot90's Avatar
The MAS can be affected if your ECU doesnt pick up the changes and componsate for the gained air flow. That happened to my car, but all i did was take out the main ECU fuse for 30 seconds and put it back in.
This should reset everything and the ECU you catch up and recognize the difference.
Old Jan 14, 2008 | 07:30 PM
dragonle87's Avatar
really the accord doesn't have a MAF???
then how does it perform the amount of air going into the engine?
Old Jan 14, 2008 | 08:12 PM
Grandhustleman86's Avatar
Default Re: (dragonle87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 &raquo;</TD></TR><TR><TD CLASS="quote">Buy a CAI or SRI from like AEM and be done, or get a ghetto ebay one and toss a K&N filter</TD></TR></TABLE>
I agree man look its money well spent....its just a simple bolt on and its something you can personally installed....take pride in your ride.
Old Jan 14, 2008 | 08:22 PM
flight50's Avatar
Default Re: (Grandhustleman86)
i was thinking the same thing. since when have accords used a MAF. second, it will be more effective getting a k&n filter with a cheap ebay tube instead of a 200 intake that basically will be the same as the cheap stuff. CAI's are iffy. depends on your climate. if you get alot of rain/flooding, skip the CAI and do short ram.
Old Jan 15, 2008 | 08:11 PM
dragonle87's Avatar
you can always do a bypass valve on the CAI
Old Jan 15, 2008 | 08:49 PM
pos_cd5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonle87 &raquo;</TD></TR><TR><TD CLASS="quote">really the accord doesn't have a MAF???
then how does it perform the amount of air going into the engine? </TD></TR></TABLE>
it uses a MAP sensor. i also read about the MAF problem with K&N filters, overall from what i have read i believe it to be false, and a easy excuse for the dealership to point fingers. but who knows.
as far as the drop-in filter, i say its worth it definately. but the ebay pipe + K&N cone filter is another option too. really depends on what you want out of it.
Old Jan 15, 2008 | 09:06 PM
smileysmile's Avatar
Well worth the buy. The only thing you have to do is buy a recharge kit instead of another filter which rules.
Madvillian45
Aug 19, 2006 08:26 PM
skylinevo
Jul 7, 2006 08:47 AM
Brian-Brian
Jun 5, 2003 09:35 AM
jwrcivicdx
10
May 5, 2003 04:06 AM
