F22B1 Auto Trans work with F23A1 engine mount and all???
Old Jan 13, 2008 | 05:14 PM
ESP.net's Avatar
Default F22B1 Auto Trans work with F23A1 engine mount and all???
Will a F22B1 Auto Trans work with a F23A1 engine in a 98+ Accord will the 98+ mount fit on the F22B1 Auto Trans 94-97?
Old Jan 13, 2008 | 10:10 PM
BlkChryKord's Avatar
Should all bolt up fine. As for the TCU and wiring, that may be a problem.
Old Jan 14, 2008 | 12:12 AM
YeuEmMaiMai's Avatar
Default Re: (BlkChryKord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkChryKord &raquo;</TD></TR><TR><TD CLASS="quote">Should all bolt up fine. As for the TCU and wiring, that may be a problem.</TD></TR></TABLE>
mechaically it'll work
electrically, it won't
Old Jan 14, 2008 | 12:23 AM
Reading comprehension pwns you. Thats exactly what I said.
And actually he could probably work around the wiring if he really wanted to. But for simple plug and play, it most likely will not work.
Old Jan 14, 2008 | 12:50 AM
lol I was agreeing with you............
I quess you could not figure it out............... maybe next time I will add a few more words to make it easier for you OK?
and he would not be able to work around the electrical part since the TCU controls more things on the 98-02 accords than it did in previous models he would have to do a lot of work and he might as well change it to a manual as it would be cheaper
newer trans has things like linear pressure switch that is controlled by the TCU
Old Jan 14, 2008 | 01:47 PM
raceACCORDingly's Avatar
if he runs a 96-97 tranny which had the tcu incorporated into the ecu it may work, but im pretty sure he's just asking about the mechanical aspect
Old Jan 14, 2008 | 08:29 PM
ESP.net's Avatar
Default Re: (raceACCORDingly)
Year stamped on engine on head is 96 which means it was in a 97... ID tag of tranny says BOYA ... reason i am asking is someone was interested in it and may have a 98 plus car just wanted to know before i sell someone something...
I was curious about everything electrical and mechanical... mount is the same too for the trans? and rear bracket?
dayne808
May 6, 2009 06:07 PM
live2race17
Aug 11, 2008 07:46 AM
ekslammed
Acura TL, RL & ZDX
Feb 13, 2008 01:04 PM
viciousvisionslarry
Dec 27, 2007 09:13 PM
drewbie*
Dec 29, 2005 02:04 PM
