b16a in crx....
Old Jan 13, 2008 | 04:54 PM
86crxintheworks's Avatar
Default b16a in crx....
wat throttle cable to use or wats best kind to buy?????
Old Jan 13, 2008 | 04:58 PM
GSX 4G63T's Avatar
90-93 DA acura integra gsr or ls or rs throttle cable. remember to also get the clutch cable.
Old Jan 13, 2008 | 05:02 PM
trustnoone7935's Avatar
Default Re: (4163175587)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4163175587 &raquo;</TD></TR><TR><TD CLASS="quote">90-93 DA acura integra gsr or ls or rs throttle cable. remember to also get the clutch cable.</TD></TR></TABLE>
What he said
Old Jan 13, 2008 | 05:03 PM
CRX30436's Avatar
Default Re: b16a in crx.... (86crxintheworks)
i agree with the throttle cable... i kept my stock clutch cable but i think the da cable is stronger so i would consider it also.
Old Jan 13, 2008 | 05:06 PM
GSX 4G63T's Avatar
Default Re: b16a in crx.... (CRX30436)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX30436 &raquo;</TD></TR><TR><TD CLASS="quote">i agree with the throttle cable... i kept my stock clutch cable but i think the da cable is stronger so i would consider it also.</TD></TR></TABLE>
the DA clutch is not stronger its just 3mm longer than the stock si cable. same material but different length. that's all. Oh yeah get the da axles and half shaft and da rear trans bracket and get a del sol b16a linkage...perfect fit with no welds ot cuts.
Old Jan 13, 2008 | 05:10 PM
Default Re: b16a in crx.... (4163175587)
thanks for the advise.i already have the axles and shift linkage.all through hasport.just these last few things before its running.thanks above to all that helped!!!
CRX30436's Avatar
or u can just buy them from hasport!!!
Old Jan 13, 2008 | 05:12 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86crxintheworks &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the advise.i already have the axles and shift linkage.all through hasport.just these last few things before its running.thanks above to all that helped!!!</TD></TR></TABLE>
even the subharness for VTEC
Old Jan 13, 2008 | 05:16 PM
CRX30436's Avatar
even that. i got every thing from hasport, custom wire harness,subharness, shift linkage, all the mounts, axles and a locash racing ecu.
Old Jan 13, 2008 | 05:39 PM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX30436 &raquo;</TD></TR><TR><TD CLASS="quote">even that. i got every thing from hasport, custom wire harness,subharness, shift linkage, all the mounts, axles and a locash racing ecu.</TD></TR></TABLE>
Do you plan on replacing all the pumps and flywheel, clutch and cams?
Old Jan 13, 2008 | 06:51 PM
i see ur from georgia wat part?im doing this build for a buddy of myne and we already replaced alot.new timing belt and water pump.new clutch and flywheel.clutchmasters stage 3!! got all wiring done and he bought a full race turbo kit to go on it.wer taking it to florida to get tuned on hondatat at like 10 puonds stock motor...hoping for maybe 300hp...should be done soon...oh and it was just painted.new front end vis cf hood.mugen rims...!!pics will be up soon....
Old Jan 13, 2008 | 07:01 PM
GSX 4G63T's Avatar
yeah, I can help you at.
Old Jan 13, 2008 | 07:22 PM
powerpro_69's Avatar
can u use the stock SIR rear tranny mount in a crx to cant you
Dosvita
Mar 20, 2005 03:01 PM
MapofurheadCrx
Jan 27, 2005 09:51 PM
Origin
12
Feb 3, 2004 06:14 PM
sCeRaXn
Mar 3, 2003 05:46 PM
CRexcellence
Dec 11, 2002 03:12 AM
