broken cam help!
Old Jan 13, 2008 | 01:57 PM
Prudz_lude's Avatar
Default broken cam help!
hey guys, i am looking at picking up a 92-95 hatch back. Just got back from looking at the car and the cam is cracked. Its fairly priced but i am wondering if the block would still be fine? I can see the valves being bent but do you guys think the bottom end is still in good running order? I guess the only way to find out is to take the head off but what could have potentially happen?
Old Jan 13, 2008 | 02:15 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: broken cam help! (Prudz_lude)
so the cam is just cracked from what you can see?? to get straight to the point ..the only way your going to find out is when you remove the head, its not very hard....and its better to be safe then sorry...i've seen cams break with near to nothing carnage then i've seen some pretty nasty **** happen when a cam breaks...
Old Jan 13, 2008 | 02:16 PM
Throwdown's Avatar
....it posted twice..
Old Jan 13, 2008 | 02:50 PM
Prudz_lude's Avatar
Default Re: broken cam help! (Throwdown)
yah thats what i think i will be doing. The cam is in two seperate pieces. The valve cover is already off so i could actually see it.
Old Jan 13, 2008 | 03:04 PM
Targa250R's Avatar
be professional
Depends on why the cam broke. If it broke from seizing due to oil starvation, then the rest of the engine isn't going to be too desireable.
Avi
Mar 27, 2007 04:42 AM
rough_draft
Mar 26, 2005 05:32 PM
TylerH
Nov 18, 2004 07:12 PM
LshatchTurbo
Aug 18, 2002 11:53 PM
