* Different Specifications - TODA SPEC B CAMSHAFTS
Old Jan 13, 2008 | 01:39 PM
JDM-Ownz's Avatar
Default * Different Specifications - TODA SPEC B CAMSHAFTS
Someone knows because in the page of TODA RACING (http://todaracing.com/category?secti...4&cid=22&id=10), says:
Camshafts TODA Spec B:
Spec B IN 250(11.0mm) 250(11.0mm) 295(12.0mm)
Spec B EX 250(11.0mm) 250(11.0mm) 285(12.0mm
And in many forums (included this one) this information about the same cams:
In: 12.0 mm 255 @ 1mm
Ex: 12.5 mm 255 @ 1mm
or
INTAKE lift - 12 mm, duration 255 @1mm
EXHAUST lift - 12mm, duration 245 @1mm
http://www.hondatech.com.au/fo...t=537
http://hondaswap.com/reference...28669/
http://www.ek9.org/forum/resou....html
Which are the real measures? . That went out new versions of the Spec To (A2) and the Spec C (C2), but of the Series B there are no variants.
Thank you.
Old Jan 13, 2008 | 02:30 PM
RStoR's Avatar
Default Re: * Different Specifications - TODA SPEC B CAMSHAFTS (JDM-Ownz)
Here is what I have saved.....but a quick call to AKH may be worth the effort.
TODA B:
adv duration-> int:295/ext:285
Pri/Sec lobe lift: 11.0mm(int&ext)
Vtec lobe lift: 12.0mm(int&ext)
Valve lash:0.2mm (cold)
intake:
pri/sec lobe:
int open BTDC:0
int close ABDC:30
cam top center:105
duration@1mm:210
vtec lobe:
int open BTDC:25
int close ABDC:50
cam top center:102.5
duration@1mm:255
exhaust:
pri/sec lobe:
ext open BBDC:30
ext close ATDC:0
cam top center:105
duration@1mm:210
vtec lobe:
ext open BBDC:45
ext close ATDC:20
duration@1mm:245
Old Jan 14, 2008 | 09:10 AM
JDM-Ownz's Avatar
Default Re: * Different Specifications - TODA SPEC B CAMSHAFTS (RStoR)
Sure,
This information also I have it, the differences in the measures it is that are generated by that the measure in duration is not to @1mm at the time the results they are not the same. The real specs in comparisson
The real measures in comparison to all them of @1mm, are a bit minor.
Regards.
Old Jan 14, 2008 | 09:33 AM
TODAwhore's Avatar
The two cams have 12mm of lift..
Old Jan 14, 2008 | 10:31 AM
JDM-Ownz's Avatar
Default Re: * Different Specifications - TODA SPEC B CAMSHAFTS (TODAwhore)
Yes, But i found different specifications about the DURATION, not the same.
Old Jan 14, 2008 | 11:25 AM
TODAwhore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">
TODA B:
adv duration-&gt; int:295/ext:285
intake:
pri/sec lobe:
int open BTDC:0
int close ABDC:30
cam top center:105
duration@1mm:210
vtec lobe:
int open BTDC:25
int close ABDC:50
duration@1mm:255
exhaust:
pri/sec lobe:
ext open BBDC:30
ext close ATDC:0
cam top center:105
duration@1mm:210
vtec lobe:
ext open BBDC:45
ext close ATDC:20
duration@1mm:245</TD></TR></TABLE>
This is the right info.....
Old Jan 14, 2008 | 11:31 AM
JDM-Ownz's Avatar
Sure! Duration at @1mm is different.
Thx!
AM
Old Sep 6, 2010 | 12:06 AM
Nowiii's Avatar
Hi guys!
I brought about two years ago used cams on ebay. The guy told me that they are BC4's so I tried to use camcard for BC4's and nothing actually worked. I decided to google for the cams I have. The only thing I was looking for was stamp with letter B at the end of camshaft, which I found was only used on Toda spec B cams. So a couple a days ago I tried to degree them. I used primary IN and primary EX. At first I tried 0 valve lash and intake duration @1mm was 177 degrees and 220 degrees on the exhaust. When I degreed them the cam gears were like 10 degrees advanced on exhaust and 4 degrees retard on intake. I'm running B20vtec 12.0 CR, Skunk2 valvetrain. Could those be fake cams?
Old Sep 7, 2010 | 02:28 PM
TheShodan's Avatar
Moderator
They could also be Blox cams IIRC
hondapowerb16a2
Apr 15, 2009 08:08 AM
manoy
Feb 21, 2008 07:12 PM
hytec
Nov 4, 2006 12:41 PM
Turbo R
Aug 15, 2002 07:36 PM
