91 crx si b16a swap help
Old Jan 13, 2008 | 01:14 PM
the_rex's Avatar
Default 91 crx si b16a swap help
i need help on how to pull axles and wiring has been tough to find out how to really do it correctly and do i have to add anything to my engine for the vtec to run fine are they easy to drop in and wire i alreay have did alot of it like the harness is all disconnected and radiator is out and all that good stuff just need help on how to pull it and the axles and vtec wiring and i would like to kno what all i willl need i also kno both my ecu in my 91crx and the new b16a are obdo
Old Jan 13, 2008 | 01:24 PM
CRX Toad's Avatar
Default Re: 91 crx si b16a swap help (the_rex)
https://honda-tech.com/zerothread/1508680
Old Jan 13, 2008 | 05:12 PM
trustnoone7935's Avatar
Try the FAQ everything you need and more
Old Jan 13, 2008 | 05:15 PM
GSX 4G63T's Avatar
http://www.phatwhippincrx.20m.com/custom.html
Old Jan 13, 2008 | 09:34 PM
Hi-Tech Honda Girl's Avatar
axles??? as in taking them off?
but as for the wiring... try rywire.com. they might be able to help.
92civiccxeglove
Oct 7, 2007 07:16 AM
CrXstEalin
Feb 23, 2004 08:12 PM
LD_EGSICK
Sep 20, 2003 09:12 PM
