F/S.F/T- 1991 Crx Si New Paint Si Wheels $2700.00 obo
Miami, FL. NEW PICS!! Price drop 2500 obo. Will trade for 05-06 RSX type S k swap!! Up for sale is my 1991 Honda CRX si. The GOOD---- Clean title 1991 Honda CRX Si. Exterior Beautiful 2 tone metallic blue and frost white paint, Projector low beam Headlights, Oem Clear style corner lamps, hidden yellow round fogs in the front custom mesh grille, Oem Front lip paint matched, molded side skirts, acrylic sunroof insert with stainless hardware urethane sealed, paint matched door handles, shaved moldings, emblems, squirters, front bumper fogs and signals. Suspension OEM CRX si front and rear disk brakes,99-00 Si wheels with new Michelin tires 195/65/15 coilover springs, F/R sway bars, with urethane bushings and end links,Ride height (Fender to Floor) 23 inches front/23.5 inches rear. Professionally lowered and aligned by Miami Chassis & Alignment in Miami
Engine/Tranny4-2-1 race header, resonator, 2inch universal catalytic, 2 inch piping to Supertrapp tunable muffler tip exhausting out passenger side. Short ram intake tube, new filter, adjustable 6 bolt aluminum Cam gear, Stage 3 6 puck ceramic clutch, 9 lb aluminum flywheel, 2 lb Aluminum crank pulley, OBX limited slip differential, 2 spare transmissions will be sold with the car. Interior CRX Si seats newly upholstered, HF Door panels clean condition, Autometer shift light, teflon white 5 speed shift ****.
The "Not so GOOD"----As of now the car has No A/C, P/S, Radio, spare tire, rear compartments, glovebox. & i have push button start with ignition flip switches (No key to start the car) but i have keys to lock the doors and pop the hatch. SOHC Engine has 120,000 miles. Lastly all maintenance has been done up to date, including oil changes & valve adjustment. I have owned the car for about 4 years. Since i bought the car it has not slept a night outside my garage. Also all the car and all upgraded parts have not seen more than 1500 miles some parts less than that since i have owned it.
That sums it up pretty much i may be forgetting some minor details but ill keep you posted. Hope this helps
More pics will follow. I open to any offers and or trades even lowballers let me know what you got. Thanks for lookin.
Modified by 02dsmbase at 2:39 PM 1/13/2008
Modified by 02dsmbase at 12:18 PM 1/20/2008
Just an FYI, your battery terminals are incorrectly connected and it might be affecting your charge system.
You see that metal plate on them? You are supposed to position the cables in between that and the terminal.
my terminals are connected correctly and there is no issues with the charge system i have had that configuration for a year or more and its always started run without any hesitation. just an fyi
