help!!
Old Jan 13, 2008 | 10:59 AM
boost6ef9's Avatar
Default help!!
is it possiable to have a ecu keep throwing 41 if you hook a o2 up wrong then put a good one thats prewire up??
Old Jan 13, 2008 | 11:12 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: help!! (boost6ef9)
wait so you had one wired in and then switched it to the plug in o2? i'm just trying to make sure i undersdtand...what your saying
Old Jan 13, 2008 | 11:23 AM
boost6ef9's Avatar
Default Re: help!! (Throwdown)
ya i had a o2 that the 4 wires were cut so i tried just connecting the wires to a plug i had laying around well it still threw the code. so put one that was already wired all up. i knew this 02 was good for a fact also.all i had to was plug it. now the ecu is still doing it. i unplug the the battery for a litt to reset the ecu. its still doing it. thanx for your help to
Old Jan 13, 2008 | 11:31 AM
Throwdown's Avatar
just wondering but how do you know that o2 is good? was it bought new from a auto store ...the reason i'm going there is because lets say you took it outa a friends car and it was working..you could have damaged it removing it or installing it...i've even seen new ones damaged
Old Jan 13, 2008 | 11:41 AM
boost6ef9's Avatar
no it wasnt bought new. the ecu wasnt throwing any codes at the time so i took it out put it in my car to see if my ecu would stop throwing it. well it didnt so i put it back in her car now its throwing the o2 code also. before any of this i tried wiring up the o2 i had laying around couldnt get it to stop. i took the o2 i had to her car and tryied wirring it up cause i knew her car was fine. now hers is doing it even when i put her o2 back in
Old Jan 13, 2008 | 11:46 AM
boost6ef9's Avatar
also i out a p28 ecu in thats auto and its not throwing any codes that why im wondring if fried the ecu
Old Jan 13, 2008 | 12:11 PM
Throwdown's Avatar
so with the plug in o2 and the other ecu there is no problems no CEL's?? if so then i think you answered your own question...get a new ecu
jdmazm
Apr 22, 2006 05:13 PM
SOHC_Brian
Nov 13, 2005 08:17 AM
slowbluhatch
10
May 20, 2005 08:08 AM
NYSiRacer
13
Jul 29, 2004 05:19 PM
smkngsr
Jun 4, 2002 12:22 PM
