Question on re-wiring corner lights to bottom turn signal 94-97
Old Jan 13, 2008 | 09:25 AM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Question on re-wiring corner lights to bottom turn signal 94-97
Just wanted to know if there was a way to re wire the corner lights with the bottom turn signals.
I would like the the corner lights to turn on along with the bottom turn signals.
But I also wanted the bottom turn signals to be functional when I hit the stalk on the steering wheel
If its not possible then just say that.
Thanks.
Old Jan 13, 2008 | 12:48 PM
sony224422's Avatar
Default Re: Question on re-wiring corner lights to bottom turn signal 94-97 (B18c5__Owns)
if you cut the power line to the parking light and then hook it up to the blinker that will make it blink with the corner.
if you want to retain the parking lights and still make it blink.. its probably not really possible without relays of some sort. i guess you could do it by ungrounding it thru the relay.
Old Jan 13, 2008 | 09:39 PM
A_Rotary_Guy's Avatar
I was also thinking of doing this. Basically making the front signal lamps stay on when you turn the parking lights on and then blink when using the turn signals.
Old Jan 15, 2008 | 01:10 AM
Default Re: (A_Rotary_Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A_Rotary_Guy &raquo;</TD></TR><TR><TD CLASS="quote">I was also thinking of doing this. Basically making the front signal lamps stay on when you turn the parking lights on and then blink when using the turn signals.</TD></TR></TABLE>
Yes, this is what I am trying to do.
Old Jan 15, 2008 | 03:57 AM
Obviously all that should be required is splicing into the corner light wires. IIRC, the front signal lamp is a dual-filament bulb, so it should work. I couldn't tell you for sure how you're going to wire it up because I don't know the wire colors or what they do - this is something you'd have to figure out from a wiring diagram.
Old Jan 16, 2008 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A_Rotary_Guy &raquo;</TD></TR><TR><TD CLASS="quote">Obviously all that should be required is splicing into the corner light wires. IIRC, the front signal lamp is a dual-filament bulb, so it should work. I couldn't tell you for sure how you're going to wire it up because I don't know the wire colors or what they do - this is something you'd have to figure out from a wiring diagram.</TD></TR></TABLE>
The front turn signals are not dual filament bulbs. I know if they were I wouldnt have this problem.
Old Jan 16, 2008 | 04:02 PM
TheMuffinMan's Avatar
He knows where you live!
Wire the ground of the corner light to the + of the turn signal.
The Positive of the turn signal acts like a ground when disabled, and power when it's on. So the result will be alternating lights.
BUT it will stay turned on when you do the corners since the positive acts like a ground.
Flip the signal on and it'll alternate with your turn signal (turn on, corner off, turn off, corner on)
Old Jan 22, 2008 | 03:26 PM
Dust Busta's Avatar
Default Re: (TheMuffinMan)
I Just did this about a week ago and it's fairly simple.
first you need to get a dual filiment socket. I bought mine at napa for $7, and I think I was for a 95 civic.
I connected the positive to the positive corner light and one of the two ground wires to the ground on the corner light.
Then I connected the last wire to the positive wire for the bumper light.
Works great! The light stays on a blink nice and bright when the turn signals on!
Old Jan 22, 2008 | 03:39 PM
Dust Busta's Avatar
Default Re: (Dust Busta)
The first time that I tried this I just hook the positive and ground from the bumper light to the corner
light. Now the corner light doesn't blink anymore.
I checked all of the fuses and they seem to be good.
could it be a rely? if so, which one?
Old Jan 22, 2008 | 04:02 PM
Did you look at the bulb?
Is the wiring from the splice to the corner incorrect?
Etc.
Old Jan 23, 2008 | 12:14 PM
Dust Busta's Avatar
ya, the bulbs 1157, and two wires go to the corner lights and one to the bumper light
Old Jan 23, 2008 | 12:21 PM
My question though was the wiring going to them messed up?
Did it pull away from the terminal, etc
Old Jan 23, 2008 | 03:47 PM
Dust Busta's Avatar
I'm not too sure what you mean
Old Jan 23, 2008 | 03:55 PM
You say you have a wire run to them.
That's not saying whether or not the actual copper of the wire is coming in contact with the terminal.
So have you looked to make sure the power is actual making it to the light itself?
ohbuckeyes
Dec 16, 2011 10:59 PM
my_gsr_teg
Apr 27, 2008 03:09 PM
o0oz
Jan 3, 2007 08:22 AM
aZnAcCoRd02
Dec 22, 2004 10:38 PM
Pandahatch
11
Dec 8, 2004 01:49 PM
