turbo
Old Jan 13, 2008 | 08:21 AM
spies1602's Avatar
Default turbo
whats better for turbo ls or b20? what one will make more power stock
Old Jan 13, 2008 | 08:23 AM
JKov240's Avatar
Default Re: turbo (spies1602)
LS...the B20 has weaker cylinder walls if I remember correctly.
But you might wanna search around and see what some people are running.
Old Jan 13, 2008 | 08:29 AM
BryanM.'s Avatar
Resident Gearhead
Go to the Forced Induction forum or have a mod move this for you. You'll get a better response there.
bluedragon's Avatar
what are you planning on runing with it are you going to a vtec head conversion?
I would say if your going to do somthing like that and turbo LS, But if you want stonger stroke and a little more power I would say b20 I have seen both built and tubo'd they are both good choices it's just up to your prefrence
Old Jan 13, 2008 | 08:45 AM
spies1602's Avatar
Default Re: turbo (bluedragon)
it will be none v
Old Jan 13, 2008 | 09:30 AM
96electronH's Avatar
id go ls its a good platform to start with and build fairly inexpensive and easy
Old Jan 13, 2008 | 09:37 AM
Hatch92's Avatar
sleeve the b20 and boost that.
Old Jan 13, 2008 | 09:41 AM
krucial7integra's Avatar
Default Re: turbo (JKov240)
agreed.
Old Jan 13, 2008 | 09:44 AM
.PLUMMM's Avatar
I prefer the Ls, because the numbers are proven to be consistant and the walls aren't as thin. You have got to search though man. It's been covered so many times...
Old Jan 13, 2008 | 09:48 AM
oneiro's Avatar
what's your horsepower range? Each block has it's limits, and with the right tuning you can achieve that limit.
Good luck
Old Jan 13, 2008 | 10:47 AM
ke98248's Avatar
Default Re: (oneiro)
Turbo the LS.
Old Jan 13, 2008 | 10:56 AM
Ekb18c5_BR's Avatar
Default Re: (ke98248)
ls....
sohc-ek4
Jun 8, 2009 12:14 PM
callmecannon
Apr 27, 2008 07:03 PM
FinedTuned
Feb 21, 2007 05:46 PM
Ultimate Weapon
37
Oct 19, 2004 07:24 PM
Matt B
Jan 27, 2002 06:51 PM
