crazy CEL
Old Jan 12, 2008 | 10:38 PM
sohcdestruction's Avatar
Default crazy *** CEL
Ok so my ecu was throwin code 16 so I checked my injectors my adj fpr was expletiveed so I put the stock one on and my injectors were leaking so I replaced the seals and whatnot cleaned them cleaned the seats and rail put seafoam in the motor and all that good **** and now my CEL is still on but now its throwin some crazy **** this is the best way I can explain it
2 long flashes 1 short flash pause 6 short flashes pause repeat pattern
Im runnin d16y8 with a6 dizzy a6 manifold and b16a ecu the vtec is ran to the ecu (I did not do this swap or the wiring I got the car like this) what do I check first cause I don't know what the hell that code is
Old Jan 12, 2008 | 10:52 PM
wakaranai's Avatar
Default Re: crazy *** CEL (sohcdestruction)
It looks like you are flashing code 21 then code 6.
Old Jan 13, 2008 | 06:11 AM
GSX 4G63T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcdestruction &raquo;</TD></TR><TR><TD CLASS="quote">Ok so my ecu was throwin code 16 so I checked my injectors my adj fpr was expletiveed so I put the stock one on and my injectors were leaking so I replaced the seals and whatnot cleaned them cleaned the seats and rail put seafoam in the motor and all that good **** and now my CEL is still on but now its throwin some crazy **** this is the best way I can explain it
Im runnin d16y8 with a6 dizzy a6 manifold and b16a ecu the vtec is ran to the ecu (I did not do this swap or the wiring I got the car like this) what do I check first cause I don't know what the hell that code is</TD></TR></TABLE>\
21*
Accord Civic CRV CRX Del Sol Odyssey Prelude
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95 VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
Old Jan 13, 2008 | 07:07 AM
Default Re: crazy *** CEL (4163175587)
Ok I was thinking it was those two codes but I wasn't sure if the car threw 2 seperate codes at one time
Ok so most likely its the wiring to the vtec and whatnet it could be the solonoid tho ill check that out or get it checked out
Where is the ect sensor located?? My car never has overheated so I'm gonna say that its defective so ill go ahead and replace that
Old Jan 14, 2008 | 12:41 PM
Ok so now I can add code 17 to the bunch and I know that is the speed sensor so I can fix that one lol
On this ect sensor where is it?? So I can check the wiring and possible replace it cause my car does not run hot it never overheats!?
WrongWD
16
Jul 1, 2007 11:13 PM
tissimo
Jan 5, 2006 10:15 PM
crxforum
Jun 12, 2004 06:07 PM
slowdx
16
Jan 23, 2004 08:20 AM
brbHPR
Jun 15, 2003 05:25 PM
