caps that fit ENKEI RPF1 WHEEL
Why not measure, then check the honda cap sticky at the top of the w/t forum. If you don't find what you want there, at least you can post the size cap you need so it's easier for someone to respond.
i did check out the search engine on the wheel and to my surprise nobody had a answer to this question..... But i will get a measurement of the bore and post it later... thanks for your opinion!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravisDTD »</TD></TR><TR><TD CLASS="quote">Discounttiredirect.com sells the Enkei cap for them</TD></TR></TABLE> in for results of that. i always thought the 17" and above rpf-1 was the only size that accepted the cap..
Enkei has always stated that they don't come in a cap except in a 17 or bigger
What size is the opening? I have enkei racing peaks caps that are about 60 mm or less. Racing peaks were the 2pce version of the old rp-01 and I think the rp in the 'rp'-f1 prolly stands for racing peaks also hehe.. Let me know.
lando griffin
Oct 25, 2007 06:17 PM
