what tool do i use to un bolt arp head studs?
Old Jan 12, 2008 | 09:09 PM
A-'s Avatar
A-
Default what tool do i use to un bolt arp head studs?
what socket do i use to with arp head studs..
:slap:
Old Jan 12, 2008 | 09:17 PM
Frozen E's Avatar
H-T White Ops
12pt something or another.
Subscribing because I forgot what size I needed, and I need to re-torque my head.
Old Jan 12, 2008 | 09:54 PM
ddd4114's Avatar
Default Re: what tool do i use to un bolt arp head studs? (A-)
12mm 12 point deep socket
Old Jan 12, 2008 | 11:25 PM
i_am_a_black_man's Avatar
Default Re: what tool do i use to un bolt arp head studs? (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">12mm 12 point deep socket</TD></TR></TABLE>
FAIL
You need a 13mm 12pt deep socket and extension
Old Jan 13, 2008 | 07:51 AM
ddd4114's Avatar
Default Re: what tool do i use to un bolt arp head studs? (i_am_a_black_man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_am_a_black_man &raquo;</TD></TR><TR><TD CLASS="quote">You need a 13mm 12pt deep socket and extension</TD></TR></TABLE>
That's odd. A 12mm socket worked fine for me...
However, just for you, I'll double check in the garage today.
Old Jan 13, 2008 | 07:56 AM
pdiggitydogg's Avatar
1/2" 12pt is the correct size
13mm fits, but its not perfect
Old Jan 13, 2008 | 08:39 AM
ddd4114's Avatar
Default Re: (pdiggitydogg)
I just checked; I used a 12mm socket for mine.
Also, when I first installed them, I didn't have the socket, so I tried to use a 1/2" (12.7mm) 12pt deep socket instead. It seemed to fit well, and the first 9 of 10 nuts were torqued down with no issues. However, I started to strip the last one as I approached 60 ft-lbs. When I bought the correct socket (12mm), it fit perfectly, and I never had had a problem (and I've reinstalled the head since then).
Old Jan 13, 2008 | 08:48 AM
Hardedge's Avatar
I don't see why they would vary between B series engines, but the ones I got for my B16A2 require a 13 mm, 12 point, deep socket. A 12 mm simply would not fit. By the way, I torqued all the way to 70 lb-ft without any slipping/stripping issues at all. If you're unsure, just take one of the nuts and test its fitment on different sockets. Oh, and you don't necessarily need a 1/2" drive. I had to use a 3/8" drive because that's the size of my good torque wrench.
Old Jan 13, 2008 | 08:57 AM
ddd4114's Avatar
Default Re: (Hardedge)
If that's the case, maybe the b and d series ARP studs are different.
OP: what engine do you have?
Old Jan 13, 2008 | 09:07 AM
A-'s Avatar
A-
Default Re: (ddd4114)
lsv. its a 12mm i looked. thanks for the help!
Old Jan 13, 2008 | 09:15 AM
Prudz_lude's Avatar
Default Re: (A-)
sorry for the highjack, but where is a good cheap (cheap is key) place to buy arp head studs for d series engine?
Old Jan 13, 2008 | 09:17 AM
ddd4114's Avatar
Default Re: (Prudz_lude)
I got mine from Summit Racing for $100. You can probably get them for a lower price via an eBay seller.
Old Jan 13, 2008 | 09:20 AM
nautique196's Avatar
Why don't you just call ARP and ask? they will tell you exactly, and you wont have to risk stripping your nuts.
Old Jan 13, 2008 | 09:21 AM
ddd4114's Avatar
Default Re: (nautique196)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautique196 &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just call ARP and ask? they will tell you exactly, and you wont have to risk stripping your nuts. </TD></TR></TABLE>
That would be too easy.
projectef
Nov 7, 2008 12:15 PM
rice a roni
21
Apr 17, 2007 09:23 AM
Mikey3000
Jan 4, 2006 03:50 AM
D
Jan 8, 2004 04:01 PM
boostedcvc
Jan 2, 2004 06:21 AM
