urgent question b16a1 original td-22u dizzy replace with td-28u?
hey guys , i got a b16a1 original dizzy (jdm ef9) was td22u but its stuffed
will a td-28u work on my b16a1 ?
im about to cut wires to solder new plugs on .
cheers guys
cheers guys
Is it a OBD1 distributer that your changing it to? And I guess your still running the OBD0 ecu?
So, I run an OBD1 Ecu and an OBD1 Distributer however i made a jumper from a seperate harness so i wouldn't need to cut the factory plugs off. So i say it should work.
Not really sure that helped a whole lot. But i do have a spare OBD0 dizzy if you want to buy it.
hey yeah im runnig a obd0 ecu , i just wanna stay that , but just not sure if the td28u dizzy will work properly i dont know if dizzy is obd1 or obd0 ?
ludesrv
May 12, 2007 08:58 PM
