Fab'd up some Int. Endtanks today
Old Jan 12, 2008 | 06:11 PM
96 GSR-T's Avatar
Default Fab'd up some Int. Endtanks today
I continually get bored with the same ****, my friend has a sheet metal fab shop, so while looking at my car deciding what to hack up next I decided to hack up my Precision 750hp Intercooler, turned it into a backdoor with BOV on endtank and a 3" outlet that will probably be a V-Band when I am done. I did all the measuring, cutting and bending, friend did the Tig'n. I also used a thick 3" piece of pipe for the Endtank Inlet and put it on a Lathe and turned it most of the way down to mimick a bead roll for the clamp to have something to hold on to. The pass. side endtank is not welded yet, may re-do that one to have the outlet more towards the top, its a little too close to the corner light as it is now for my liking. Enjoy.
Yesterday:
Today:
Plan to run 3" Alum Piping through this hole will end up making a custom fender bracket for this.
And bumper on:
He also has a mandrel bender but I am not sure now that will come out looking with thin Aluminum for the piping, dont want to use stainless, curious to see the outcome. Next 2 weeks we will also be fabbing a large catch can (T1 Style) and welding in my Moly 8pt and then possibly an 4" Al. Intake.
Old Jan 12, 2008 | 06:32 PM
DESTROYER's Avatar
holy cow what is the thickness of the sheet for the end tanks?
Old Jan 12, 2008 | 06:34 PM
96 GSR-T's Avatar
lol I forget, now that I look at it the pics make it look thicker than it really is, it was just as thick as the top and bottom portions of the core, maybe a cu*t hair thicker.
Old Jan 13, 2008 | 04:59 AM
DaveF's Avatar
Default Re: (96 GSR-T)
damn, that intercooler is beast ! im assuming you will be fabing up some new mouting brakets ?
Old Jan 13, 2008 | 06:02 AM
96 GSR-T's Avatar
Default Re: (DaveF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">damn, that intercooler is beast ! im assuming you will be fabing up some new mouting brakets ? </TD></TR></TABLE>
yea seems that way, we just did those brackets a month ago I dont have a trailer so we basically just measure and guesstimate and then drive 20min to the shop and put it together.
Old Jan 13, 2008 | 07:53 AM
DESTROYER's Avatar
I failed to say earlier, good job!!!
Old Jan 13, 2008 | 12:50 PM
KENetics1's Avatar
Default Re: Fab'd up some Int. Endtanks today (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
And bumper on:
those pictures right here do make the material look really thick. Is it just the end pieces that are thicker? Looks good though
Old Jan 13, 2008 | 01:41 PM
96 GSR-T's Avatar
Default Re: Fab'd up some Int. Endtanks today (KENetics1)
[IMG]I just went out there and looked, the hotside entank in that spot never got file'd, I deburred everything but forgot that, it was drilled after the tank was assembled, there is a big lip there. Thanks for the comments guys, I think I might start taking welding classes soon, I thoroughly enjoy the fabricating part of all this, just wish I could weld it too.
Old Jan 13, 2008 | 04:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
good job ben. i like. makes me think i can do that he hee....
Old Jan 13, 2008 | 08:11 PM
G2turbo_terror's Avatar
Very nice. I'm about to convert an IC to a back door set up too.
Old Jan 14, 2008 | 09:54 AM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">good job ben. i like. makes me think i can do that he hee....</TD></TR></TABLE>
thx mikey and everybody else, need some tanks let me know, they can be diamond plate, mirror alum or whatever. went to vertex earlier and dropped $100 on some mirror 3" alum for the piping, just need to locate a Tial 50mm BOV flange.
Old Jan 14, 2008 | 11:33 AM
Mikey3000's Avatar
Does the car have solid engine mounts? Cuz if it doesn't, won't there be some issues with the hot side coupler when under load?
Old Jan 14, 2008 | 12:06 PM
rorik's Avatar
x2..
Old Jan 14, 2008 | 03:30 PM
96 GSR-T's Avatar
Default Re: (rorik)
Solid rear mount and Avid Billett Torque Mounts, the motor barely moves at all.
Old Jan 14, 2008 | 05:13 PM
JoePSI's Avatar
impressive
delspool
Welding / Fabrication
36
Jan 2, 2006 07:31 PM
tolowhb
Apr 8, 2004 10:44 AM
wrXtian
Dec 9, 2003 06:29 PM
WuShu
May 13, 2002 03:40 PM
