d16a6 question!
im gonna be doing a A6 swap soon, and i was wondering can i use the radiator, alternator, motor mounts, ecu, fuel pump, starter off my d15b2 for the d16a6???
i know im changing the transmission and the axles. but does everything fit pretty easy?
are u converting the car from dx to si? and u need the pm6 ecu, ( si) or some other multi port fuel injection ecu.. and your wiring will need to be re done. the alt and all that will work yes. u will need a diff distributor too,. and a resistor box
you don't even need to switch the axles si and dx are the same you could even use the std ones although they aren't as strong aside from the stuff mentioned above everything should swap over pretty well.
thats cool but i was wondering somone said i need to get the si ecu to make it a 5 spd or w/e but my dx is already a 5 spd would i still need the ecu or should i get it anyway
you need the pm6 to run the multi port fi really has nothing to do with being 5 spd or not do you have aol instant messenger? because i am talking to you in two different threads and wasting alot of space. send me an im sn is twiztid17thninja
88rexdxa6ed
11
Apr 18, 2003 06:29 AM
