here's my timeslip.... any advice?
reaction 0.844
60 ft 2.319
1/8 ET 9.396
1/8 mph 76.97
1/4 ET 14.578
1/4 mph 94.32
the car is a 92 eg6 vti (like a jdm siR) with abs, ps, all electrics including sunroof etc. only heavy thing that it hasn't got is air con. its got ITR brakes, susp, sway bars etc, also i'm weighing in at 120 kg. it must be about as heavy as any eg hatch you'll ever see at the strip. the only thing going for it is the uk ITR motor/box with intake, ITR exhaust, de-cat pipe, p30 chipped but for a b16a2....atleast it gets rid of the 8200 rev limit. i was running street tyres at normal pressure and ive only been to the strip once before.
i always see b18c5 civics runnin 13's no problem.... am i askin too much with all my extra weight or should i be runnin faster.
where should i shift in each gear (indicated) the rev limit is at 9700....dont ask how i found that out.
thanks in advance
60 ft 2.319
1/8 ET 9.396
1/8 mph 76.97
1/4 ET 14.578
1/4 mph 94.32
thanks in advance
definitely dont shift at 9700, your stock ITR valvetrain wont hold there, plus its not making enough power there. If you want the perfect shift points you need a dyno chart
Jawad.
60
Aug 17, 2003 11:46 AM
