grinding noise coming from belt
the car is a 1990 Ex 5spd
this morning i turned it on and it sounded like there was a grinding noise coming from where the belt is, but i cant tell. i thought it was the clutch reservoir or something because i let my friend drive it and he was burning the clutch pretty bad. anyways, any ideas?
thanks in advance
thanks in advance
yes unless you filled it way too much. There are lines on the resivoir to show high and low. if its inbetween those then yes, you have other problems. if it was above it its not a problem, so check and refill if you need to.
the ps will puke fluid if it has air in it. turn the wheel lock to lock several times and always add ps fluid with it running. once the air is out it should return to normal.
ok..well this morning it did the same thing, but in the afternoon it didnt leak at all.
i even turned it on and rotate the wheel side to side, but still has the whirling noise
NikeSB
Sep 14, 2006 04:23 PM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
ShaolinRider
Sep 24, 2003 09:27 AM
