Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 12, 2008 | 09:17 AM
civic_auto_x's Avatar
Default 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!!
ok guys i need some help here i am looking at geting some 15 inch rims but i want to get 7.0 but they only have 7.5 in stock right now and the first race is on 02/16 and i need the wheels by then so that i will be able to race right because i do not want to roll on my 17 because the wheels are shot. but any advice would be great also the tire size that i am working with is 205/50/15 any info is great
Old Jan 12, 2008 | 07:24 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (civic_auto_x)
Rota. Pick your design and go!
Old Jan 13, 2008 | 09:32 AM
Jan in Omaha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_auto_x &raquo;</TD></TR><TR><TD CLASS="quote">ok guys i need some help here i am looking at geting some 15 inch rims but i want to get 7.0 but they only have 7.5 in stock right now and the first race is on 02/16 and i need the wheels by then so that i will be able to race right because i do not want to roll on my 17 because the wheels are shot. but any advice would be great also the tire size that i am working with is 205/50/15 any info is great </TD></TR></TABLE>
What class are you trying to run in? STS allows 7.5 inch widths.
Old Jan 13, 2008 | 04:19 PM
Targa250R's Avatar
be professional
Indeed. I can't think of any class in which you wouldn't want a 15x7.5" wheel over a 15x7", unless you're running Stock and your stock wheels are 15x7". I can't say I know of any Hondas with stock 15x7s though . . .
Old Jan 13, 2008 | 06:50 PM
civexspeedy's Avatar
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (Targa250R)
yeah just get the 7.5's unless ur really looking to save every bit of weight..
Old Jan 14, 2008 | 11:55 AM
hybridmoments's Avatar
edgeracing.com
has some 15x7 Falken Hanabi for $89 each.
about the lightest cheapest 15x7 you an buy.
i ran about 15 auto-x in 2007 on them, along with 10k miles of street driving, with no issues.
15x7.5's will be a good choice too. you can get the Rota Slipstreams in that size. i have some of those still in the boxes, can't remember what they weight. like 14 lbs i believe.
Old Jan 15, 2008 | 01:38 PM
court76wi's Avatar
Man, can you fit 7.5" wheels under your car without dragging on your rear trailing arms? Must have a pretty good offset...
Old Jan 15, 2008 | 05:21 PM
Vracer111's Avatar
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (court76wi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court76wi &raquo;</TD></TR><TR><TD CLASS="quote">Man, can you fit 7.5" wheels under your car without dragging on your rear trailing arms? Must have a pretty good offset...</TD></TR></TABLE>
36mm offset 15x8 wheels clear all around on a DA integra and ED civic...
I'd run the 7.5" wheels unless the class dictates you can't....
Old Jan 16, 2008 | 07:23 AM
jbs's Avatar
jbs
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (Vracer111)
Isn't 7.5" too wide for a 205 width tire?
Old Jan 16, 2008 | 07:28 AM
Targa250R's Avatar
be professional
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">Isn't 7.5" too wide for a 205 width tire?</TD></TR></TABLE>
Not for the current crop of 195/50-15 (Bridgestone), 205/50-15 (Falken/Kumho), and 225/45-15 (Hankook) ST tires. The wider the wheel, the better these tires feel - but 7.5" is the maximum wheel width allowed in STS. 7" is okay, but 7.5" is better.
Old Jan 16, 2008 | 09:16 AM
gabebauman's Avatar
Do you already have the 205/50 tires?
Old Jan 16, 2008 | 03:34 PM
evospeed's Avatar
Default Re: 15 inch rims for autocross need help asap!!!!!!!!!!!!!!!!!!!!!!!! (gabebauman)
thanks everyone for the help and yes i do have the 205 tires and i just bought the 7.5 becasue it well give me a better contact patch and i should not rub becasue the well is a 40 offset and i might put a 5mm spacer in the wheel as well to make it work right.
Extreez
Dec 25, 2007 12:02 AM
strawberry
Nov 14, 2007 08:29 PM
sohctodohc
Suspension & Brakes
15
Sep 16, 2005 12:07 AM
90Integra
Oct 30, 2004 06:05 PM
