will del sol vtec knuckels and brakes work on 91 crx si
Old Jan 12, 2008 | 08:52 AM
crvpimpin's Avatar
Default will del sol vtec knuckels and brakes work on 91 crx si
ok i'm fixin my crx and the lower ball joint on pass side is spun and striped
so i also have some del sol vtec front knuckels with brakes and all.
will they fit on my crx?
Old Jan 12, 2008 | 09:30 AM
Targa250R's Avatar
be professional
Default Re: will del sol vtec knuckels and brakes work on 91 crx si (crvpimpin)
The geometry is different.
Just replace the ball joint. They are easy to change and are not expensive.
Old Jan 12, 2008 | 09:42 AM
crvpimpin's Avatar
Default Re: will del sol vtec knuckels and brakes work on 91 crx si (Targa250R)
how do they come out?
also will the ball joint from the dels sol work for the crx
Old Jan 12, 2008 | 09:50 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvpimpin &raquo;</TD></TR><TR><TD CLASS="quote">how do they come out?</TD></TR></TABLE>
I just beat it out with a hammer. Make sure you remove any circlips/snap rings in the way beforehand.
You could also use a shop press if you have something shaped properly to fit around the joint and knuckle, but that will require you to remove the knuckle from the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also will the ball joint from the dels sol work for the crx</TD></TR></TABLE>
Yes, but only if you can remove one without damaging it.
Old Jan 12, 2008 | 10:09 AM
crvpimpin's Avatar
thanks alot
i'll try and get the one off the delsol if not then i guess buy a new one
Old Jan 13, 2008 | 08:29 PM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvpimpin &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot
i'll try and get the one off the delsol if not then i guess buy a new one</TD></TR></TABLE>
It'll cost you a pretty pennie..but if you got a pretty one, then go for it...its so EZ, my girlfriend could do it...wait...i dont have one...****!!
Jcup315
Mar 8, 2005 09:36 PM
folta2169
72
Feb 17, 2005 01:04 PM
RoadconeTuning
Jan 22, 2005 08:44 AM
sit220
18
Apr 4, 2004 09:05 PM
cpizzy
Dec 20, 2003 08:02 PM
