Is this chunking acceptable for a tire?
is this a common thing for tires? should I try to warranty them?
They are federal 595...I know you guys will say these are cheap tires, not made for the track and I probably over drove these a little
but Im wondering if a comparable kumho or michelin or something would the same thing happened?
if its for the track only then you should just buy some drag radials. A federal tire is a cheap tire hands down. kumho and michelin tire's are a better quality tire than a federal tire. But what you see can happen to any tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starchland »</TD></TR><TR><TD CLASS="quote">is this a common thing for tires?</TD></TR></TABLE>
Not this bad, no. It's not uncommon for street tires, particularly those that are not particularly high performance or high quality, to have small chunks come out (maybe 5-10 mm in diameter), but I've never seen anything this bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starchland »</TD></TR><TR><TD CLASS="quote">should I try to warranty them?</TD></TR></TABLE>
No. They happened as a result of track use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starchland »</TD></TR><TR><TD CLASS="quote">They are federal 595...I know you guys will say these are cheap tires, not made for the track and I probably over drove these a little
but Im wondering if a comparable kumho or michelin or something would the same thing happened?</TD></TR></TABLE>
It depends on the kind of tire. Their top-of-the-line performance summer tires would not have the same thing happen. Their cheap all-season tires? I don't know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">if its for the track only then you should just buy some drag radials.</TD></TR></TABLE>
I disagree. Drag radials are good for the dragstrip, not for the track. Drag radials are designed for acceleration, with sidewall reinforcement to allow them to be used at low pressures (for a larger contact patch).
If you plan to go to the track a lot, you could get some R compound track tires, if you have a lot of track experience; otherwise, a good dual-purpose tire (e.g. Falken Azenis RT-615) might be a good idea.
but Im wondering if a comparable kumho or michelin or something would the same thing happened?</TD></TR></TABLE>It depends on the kind of tire. Their top-of-the-line performance summer tires would not have the same thing happen. Their cheap all-season tires? I don't know.
thanks extasy guy,
well these arent all seasons these are a dedicated summer tire, very good for the price! but just not trackable. A drag radial wouldnt help me cause im driving on a road course, and i need something to drive to and from the track on, so im thinking the proven 615. sux tho cause otherwise these tires still have life in them...thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chawski »</TD></TR><TR><TD CLASS="quote">anyone have experience with kumho on the track? i had some that chunked really bad like these</TD></TR></TABLE>
I've used Kumho V700 Victoracer track tires, I've instructed folks running the Kumho SPT, and I've known folks who have run the Kumho MX, all without chunking. But Kumho also makes some all-season tires and some not so great tires and it's possible their other tires might chunk.
If you're going to be doing a lot of track driving, like vtecsi00 and I both said above, you ought to get yourself either some R compound track tires (the Toyo RA-1 and Nitto NT-01 are both popular choices) if you're not going to drive them on the street, or the Falken Azenis RT-615 (which you can get from Vulcan) if you need to also drive them on the street.
sorry i should have specified.
its a 92 honda accord ex...I am running a 16 inch wheel in which the proper size would be a 205/50/16. but the closes azeni I could match was the 215/45/16 which I wouldnt running because it would give me a little more width and an smaller sidewall.
stock size for my car is a 195/60/15.
thanks for the help all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starchland »</TD></TR><TR><TD CLASS="quote">its a 92 honda accord ex...I am running a 16 inch wheel in which the proper size would be a 205/50/16. but the closes azeni I could match was the 215/45/16 which I wouldnt running because it would give me a little more width and an smaller sidewall. </TD></TR></TABLE>
My suggestion would be to try the new Dunlop Direzza Sport Z1, which is available in 205/50-16. It appears to offer performance very similar to the Azenis (e.g. it beat the AD07 and KD in testing, but not the RE01R) and it's also priced similarly too. And the diameter is right for your car. Yeah, it's narrower, but 10 mm of treadwidth isn't going to make a huge difference.
yeah ive been running 205s the last time.
you reaffirmed my decion, going to try those I think if the price is right.
you may have read my other thread on the new dunlops
Crack Monkey
Apr 6, 2006 09:37 AM
canuckr
38
Sep 14, 2002 10:45 PM
