simple cam question
I'll answer your question with another question: Have you ever seen it posted on any manufacturers website that you must use thier cam gears with their own brand of cams? Have you ever seen anyone use different cam gears from the type of cams they were using before?
noope all is see is use there valve springs and have titanium retainers, so just answer my question with a simple yes or no and ill go from there :]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burningrex »</TD></TR><TR><TD CLASS="quote">It's always better to have things match plus theToda cam gears they will fit better... I'd hate to see one of those cams break...</TD></TR></TABLE>
So if I didn't know better, I'd say you're implying that unless you run the same cam gears and cams, that you might break the cams..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongxcuz »</TD></TR><TR><TD CLASS="quote">noope all is see is use there valve springs and have titanium retainers, so just answer my question with a simple yes or no and ill go from there :]</TD></TR></TABLE>
....I see the answer...does anyone else see the answer....
Explain.
Explain.
Please, enlighten.. far i as knew..all gears fit the same on the cams..
Teamdiesel
Jan 6, 2006 12:59 PM
