how to clean injectors???
Old Jan 11, 2008 | 04:11 PM
mynameizstitch's Avatar
Default how to clean injectors???
ok the car is throwing a misfire and im just wondering how hard is it to take the injectors off and clean them? if there is a DIY please give me a link to it. or if not then how much do you think it would cost a a local shop to do the job? (would using the injector cleaner where u put in the gas tank help on this?)
Modified by mynameizstitch at 1:31 AM 1/12/2008
Old Jan 11, 2008 | 04:21 PM
blackmugensivic's Avatar
Default Re: how to clean injectors??? (mynameizstitch)
I used this stuff called BG44K in my car and it made one hell of a difference, improved gas mileage and made it run alot better, I don't remember who its made by but it comes in a silver and black can about the size of a pop can, you should be able to find it a parts house
Old Jan 11, 2008 | 04:30 PM
anyone with more advice?
Old Jan 11, 2008 | 04:36 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (mynameizstitch)
we used to charge 70 bucks for a power flush on injectors
Old Jan 11, 2008 | 04:40 PM
Padawan's Avatar
Darth ModerVader
Check the Sponsor Marketplace. There was a shop running a special on injector cleaning that should still be valid.
Old Jan 11, 2008 | 04:42 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: how to clean injectors??? (Padawan)
or if you're lazy send them here: http://www.rceng.com/Fuel-Inje...WBXZb
Old Jan 14, 2008 | 05:20 AM
sal's Avatar
sal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Check the Sponsor Marketplace. There was a shop running a special on injector cleaning that should still be valid. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1951304
$12.50
Old Jan 14, 2008 | 10:42 AM
beeze's Avatar
Default Re: how to clean injectors??? (sal)
run cleaner or take them somewhere
Old Jan 14, 2008 | 01:21 PM
sneakysneaky's Avatar
hook up a 9v source to your injector and spray carb cleaner through them.
if you dont get a decent spray pattern keep going or get a new injector.
sonic cleaning is much better but this method can be done with a spare
injector harness and a9v battery reducing downtime to a matter of minutes compared to a couple of days.
Old Jan 14, 2008 | 01:41 PM
mesonerz's Avatar
Default Re: how to clean injectors??? (blackmugensivic)
bg 44k is made by b.g. i work @ a toyota dealership and we use bg products. there pretty good. they offer a fuel induction service which works fine. id stay away from the engine flush though ive seen and heard some bad stuff about that.
Old Jan 14, 2008 | 02:18 PM
vtek9's Avatar
Default Re: how to clean injectors??? (mesonerz)
http://www.partsamerica.com/Pr...=3232
i use that every 1,000 for my cars, works fine for me.
HFXCIVIC
Jun 27, 2012 02:28 PM
lildevock
Aug 18, 2004 10:07 PM
HXvtec
Mar 17, 2004 04:27 AM
asianspeed
Mar 6, 2003 02:35 AM
Volcom
Jul 27, 2001 09:24 AM
