Lighting HID/Xenon kits, Retrofits and Associated Topics
EK stock headlight shields vs. HID kit shields
Old Jan 11, 2008 | 03:22 PM
portenio78's Avatar
Default EK stock headlight shields vs. HID kit shields
Has anyone tried cutting out the stock headlight glare shields on an EK, and only used the shield that comes with an H4 kit? Just wondering because I have an HID kit in right now and the output is great, but the bulb is buried behind 2 shields. Who knows, it might be even better with just one shield?
Old Jan 15, 2008 | 11:47 AM
ula's Avatar
ula
leave the shields. the glare will be killer without them
Old Jan 15, 2008 | 12:43 PM
IT'S ME DAVID's Avatar
NooB
Default Re: (ula)
my 9006 doesnt have glare sheields like a h4 does and the headlights dont have that built in shield either and the galre is not even noticable.
Old Jan 15, 2008 | 04:17 PM
JSPECSIR's Avatar
Default Re: EK stock headlight shields vs. HID kit shields (portenio78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>my buddy did this on his em1, it was pretty blinding. not really from a glare off the reflector, cause he still had the lower shield. it was just blinding cause you could actually see the hid capsule illuminated.
Old Jan 22, 2008 | 05:33 PM
Imp-tuner's Avatar
From: Santa Ana ES in 415 NORCAL where clean ricers are found :P
DON'T DO IT!!!!!!!!!!!!!!!!!!!!!!!!!!
I DID THAT MISTAKE!!!! AND NOW ONCE A WHILE I GET CARS LIGTHING ME TOO AND PEOPLE SAYING THINGS LIKE ....TURN UR LIGHTS OFF MODA F......ER
Old Jan 22, 2008 | 10:45 PM
CarbonizedDX's Avatar
Default Re: (IT'S ME DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">my 9006 doesnt have glare sheields like a h4 does and the headlights dont have that built in shield either and the galre is not even noticable.</TD></TR></TABLE>
9006's are low beam only, the reflector in most cases (my brothers intrepid has a minor shield) has a shield but also the optics of the lens are designed around the full output of the bulb. H4's are dual filament bulbs and if you ever look at one you'll see the low beam filament (farthest from the base) has a lil shield pan sitting under the filament.
Also a full nose cone shield is alot better than the T shaped OE shield, I've see a kit with just a lower shield in a 99-00's headlights and the T shield infront of the bulb didn't limit the light output forwards thus causing light to escape forward uncontrolled causing glare...
paul12001
Honda Civic (2006 - 2015)
Dec 25, 2007 07:29 PM
bikerballrEM2
Honda Civic (2001 - 2005)
13
Oct 3, 2007 12:20 PM
Petah
46
Nov 10, 2003 08:46 AM
BanEL
Aug 5, 2003 02:33 AM
YumVTEC
25
Mar 3, 2003 03:05 PM
