Exactly what point (rpm) you shift gears when in vtec mode?
If you're a GSR, shift as high as possible from 1st to 2nd or you might end up falling below 5700 and closing up the secondaries again. Otherwise, most will say to see where you make peak hp and use that as your shift point. it may be different for each gear. Others will say it needs to be calculated using gear ratios etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pat_S »</TD></TR><TR><TD CLASS="quote">Same answer as above. Once the needle reaches redline.</TD></TR></TABLE>
HOLY CRAP you stole my icon ahaha that was off of my car!! reppin my wheels ahaha.....
but yea, hit almost before the redline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantstandlam »</TD></TR><TR><TD CLASS="quote">
but yea, hit almost before the redline</TD></TR></TABLE>
hahaha he's a biter
hahaha he's a biter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">
hahaha he's a biter</TD></TR></TABLE>
ahaha yes he is a BITER!
i call you out to a bboy battle, you down Pat_S?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .xcalibur. »</TD></TR><TR><TD CLASS="quote">If you're a GSR, shift as high as possible from 1st to 2nd or you might end up falling below 5700 and closing up the secondaries again. Otherwise, most will say to see where you make peak hp and use that as your shift point. it may be different for each gear. Others will say it needs to be calculated using gear ratios etc.</TD></TR></TABLE>
For the B18C1, you shift right before the fuel cutoff for maximum performance. The HP will always decrease when you shift for that engine.
Why the hell would you smack your rev limiter? All that does is waste even more time before shifts after already wasting time going past the band when your motor stops making power anyway. It's vtec not vtak or vtek or vtech or vtac
About the gsr shift point. I belive the stock limiter is 8400. I shift at 8300-8400 exact and no matter what, i always drop below 5700 and takes probably 200-300 rpms to get back into the secondaries. Is this normal or is it my gearing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 »</TD></TR><TR><TD CLASS="quote">i like to bounce my car off the limiter a few times before i shift.
but my vtak switch doesnt work. i never hear the crossover.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by karma28217 »</TD></TR><TR><TD CLASS="quote">Why the hell would you smack your rev limiter? All that does is waste even more time before shifts after already wasting time going past the band when your motor stops making power anyway. It's vtec not vtak or vtek or vtech or vtac</TD></TR></TABLE>
You do not want to hit the rev limiter. For the stock B18C1, the power made at 8200 RPM is still greater than the power made at 6000 RPM. Yes, the power has already peaked before 8200 RPM, but it is a misconception that the engine stops making power. The optimal shift point in that case is just before the rev limiter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-GGSR »</TD></TR><TR><TD CLASS="quote">About the gsr shift point. I belive the stock limiter is 8400. I shift at 8300-8400 exact and no matter what, i always drop below 5700 and takes probably 200-300 rpms to get back into the secondaries. Is this normal or is it my gearing?</TD></TR></TABLE>
Yes, it is your gearing.
http://www.ff-squad.com/tech/temp/Bgears.htm
karma you have no sense of humor/sarcasm...blahblah wasn't being serious
Not everyone would catch that point due to inexperience, etc. That is why it is poor form to do that.
Yeah I didn't catch the sarcasm with the rev limiter, because:
1. I know people that do it and think thats good or means their car's fast, etc
2. The amount of people that type vtak and other incorrect iterations of vtec astound me by their randomness sometimes, so i associate that with the ricer thing not all idiots I understand but it's an automatic label when I read posts
>Quote< You do not want to hit the rev limiter. For the stock B18C1, the power made at 8200 RPM is still greater than the power made at 6000 RPM. Yes, the power has already peaked before 8200 RPM, but it is a misconception that the engine stops making power. The optimal shift point in that case is just before the rev limiter. >Quote<
Hmm... Learn something new everyday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">you would know when to shift if you got one of those 5 inch monster tachs with a shift light, and set it for 8200 rpm's.
lol....
</TD></TR></TABLE>lol....
For maximum acceleration, get the revs as high as you can without hitting the rev limiter. Shifting at redline is close enough.
For maximum fuel economy, shift with the revs as low as you can without the engine lugging after the upshift.
