Defect on CF hood, anyone know if it can be taken out (pics included)
Old Jan 11, 2008 | 01:15 PM
Civicman86's Avatar
Default Defect on CF hood, anyone know if it can be taken out (pics included)
Anyone know if this defect can be removed?? Maybe with a reclear??
http://s128.photobucket.com/al...7.jpg
Old Jan 11, 2008 | 01:25 PM
jdmturbo1127's Avatar
Default Re: Defect on CF hood, anyone know if it can be taken out (Civicman86)
Try wetsanding with 1500 grit and buff it with a polishing compound first....
Old Jan 11, 2008 | 02:57 PM
Civicman86's Avatar
anyone else every seen this?
Old Jan 11, 2008 | 04:42 PM
toyomatt84's Avatar
Sanji
It's pretty common with Carbon Fiber parts that have a clearcoat.
Old Jan 11, 2008 | 04:45 PM
Civicman86's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">It's pretty common with Carbon Fiber parts that have a clearcoat.</TD></TR></TABLE>
Can it be fixed though???
Old Jan 12, 2008 | 07:26 PM
iam7head's Avatar
Default Re: (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">
Can it be fixed though???</TD></TR></TABLE>
yes, it will not be a tough repair but make the fiber underneath is untouch, or it will need some resin/fiber work=more money
most of the cheap **** hood are not even clearcoated
Old Jan 29, 2008 | 07:51 PM
Civicman86's Avatar
I just wanted to update this thread. I got 95% of all the defects cloudiness out of the hood via polishing with orbital and polish. I feel that a good wet sand and maybe a rear clear would clear the remaining 5%.
The hood is a VIS. I'm not really sure what the root cause of this problem is. Maybe the gelcoat does not have enough UV protection?
Old Feb 4, 2008 | 10:12 AM
Nicks95GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">I just wanted to update this thread. I got 95% of all the defects cloudiness out of the hood via polishing with orbital and polish. I feel that a good wet sand and maybe a rear clear would clear the remaining 5%.
The hood is a VIS. I'm not really sure what the root cause of this problem is. Maybe the gelcoat does not have enough UV protection?</TD></TR></TABLE>
Same thing happened to my hood, aslo VIS. What did you use to take off 95% of the cloudiness?
Old Feb 4, 2008 | 10:22 AM
jmm96gsr's Avatar
Default Re: (Nicks95GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nicks95GSR &raquo;</TD></TR><TR><TD CLASS="quote">
Same thing happened to my hood, aslo VIS. What did you use to take off 95% of the cloudiness?</TD></TR></TABLE>
I would like to know too, my VIS hood is looking that.
Old Feb 4, 2008 | 08:23 PM
ebizzle361's Avatar
Default Re: (jmm96gsr)
Old Feb 5, 2008 | 04:14 AM
Civicman86's Avatar
Here is a pic of the hood after...
Old Feb 11, 2008 | 09:16 AM
Nicks95GSR's Avatar
But what products (name Brand) did you use? Thakns!!!
Old Feb 11, 2008 | 09:22 AM
Civicman86's Avatar
Menzerna Polishes (SIP and 106ff). I used a Porter Cable Random Orbital with orange (for the SIP) and white (for the 106ff) Lake Country foam pads.
If the spots reappear this summer then I think the problem is the shitty gelcoat they put on the hood. I don't think the "gelcoat" is very UV resistant and is causing the spots.
Also you should be able to tell whats actually a defect in the hood and whats a defect in the clear/gel. Some defect simply can't be removed by just polishing/sanding.
jdmjohnyyy
May 12, 2007 04:57 PM
pearlwhite01
May 10, 2006 06:33 PM
Bulldogg83
Oct 31, 2004 11:37 PM
stockredej1
12
Jan 19, 2004 08:37 PM
civic-si-2000
Jun 11, 2003 11:02 AM
