16x8 te37 with 42 offset on ek hb
Old Jan 11, 2008 | 09:20 AM
kickz's Avatar
Default 16x8 te37 with 42 offset on ek hb
hey hey
has any one ever fit these on ek hb ??
with 235/45r16 tires ??
also running wilwood bbk with 12.2 inch rotor ?
any sugguestion or pics would help alot thanks
Old Jan 11, 2008 | 09:39 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 16x8 te37 with 42 offset on ek hb (kickz)
Is this for the track? For street use, that tire size is much too big for a '97-00 Civic. Stick with 205/45-16 or 215/45-16.
Old Jan 30, 2008 | 06:45 AM
kickz's Avatar
Default Re: 16x8 te37 with 42 offset on ek hb (nsxtasy)
yes its for daily driving and some tracking
got k series .. soo the wider tire would help
Old Jan 30, 2008 | 08:30 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kickz &raquo;</TD></TR><TR><TD CLASS="quote">yes its for daily driving and some tracking
got k series .. soo the wider tire would help </TD></TR></TABLE>
No, it won't.
The big difference between tires is between models; tread width is a minor factor (and a wider tire actually makes acceleration worse). So if you want better performance, concentrate on getting better tires, rather than wider tires.
There is no street tire in 235/45-16 that will give your car better performance than the Falken Azenis RT-615 in 215/45-16 or the Bridgestone Potenza RE-01R in 205/45-16 (or, if you need something longer-lasting that does well in rain, the Goodyear F1 GS-D3 in 205/45-16). These are the best tire choices, with the best performance, for your daily-driven high-horsepower '97-00 Civic. However, the only one of these three choices approved for use on 16x8 wheels is the RT-615 in 215/45-16, so that's the one you should get.
Old Feb 4, 2008 | 05:51 PM
corndogs's Avatar
225/40/16 will work 100% I have them on my EG
Records
Mar 16, 2012 09:04 AM
boonesskr
Jul 8, 2009 09:03 AM
riseagainst
Nov 4, 2005 06:49 PM
EnzoSpeed
Jun 9, 2005 01:20 PM
Transport
Suspension & Brakes
Jan 9, 2005 08:28 PM
