Oem parts B18c with Pro1's
Old Jan 11, 2008 | 08:17 AM
.CUBISH.'s Avatar
Default Oem parts B18c with Pro1's
This is my daily driver.. Graph compares before tune, after tune, then cam swap and tune..
b18c1
pr3 pistons
arp head and rod bolts
skunk2 intake manifold
stock header
2.25 exhaust
custom length cold air with v-stack
a/c, power steering
rev springs and retainers
Skunk pro1 cams
310cc injectors
tuned with crome
going to test a header on it later today
blue=no tune..stock cams
red=tune with stock cams
green=tune with skunk pro1's
Old Jan 11, 2008 | 08:21 AM
4g hatch's Avatar
Default Re: Oem parts B18c with Pro1's (.CUBISH.)
you should make a pass with open header so we can see the difference it would make vs. the 2.25 exhaust
Old Jan 11, 2008 | 08:22 AM
.CUBISH.'s Avatar
Default Re: Oem parts B18c with Pro1's (4g hatch)
i'll prob do that once i switch the header
Old Jan 11, 2008 | 08:52 AM
mar778c's Avatar
Community Builder
Community Influencer
Thank you for this post.
It should stop a lot of questions.
Old Jan 11, 2008 | 09:13 AM
Del Sex's Avatar
Default Re: Oem parts B18c with Pro1's (mar778c)
Good looking graph, especially for such a simple build.
What header are you putting on?
Old Jan 11, 2008 | 09:17 AM
.CUBISH.'s Avatar
Default Re: Oem parts B18c with Pro1's (Del Sex)
going to try an ebay 4-1 and a rmf narrow
Old Jan 11, 2008 | 09:21 AM
.xcalibur.'s Avatar
Wow i didnt know stock cams are good for 170hp with that setup.
Old Jan 11, 2008 | 09:47 AM
Del Sex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">going to try an ebay 4-1 and a rmf narrow</TD></TR></TABLE>
In for results
Old Jan 11, 2008 | 12:15 PM
DonF's Avatar
Move the VTEC point a little higher.
Old Jan 11, 2008 | 12:19 PM
dinko's Avatar
Default Re: Oem parts B18c with Pro1's (DonF)
that's a whole lotta hp for that exhaust set up.
please post up when u retune with new header
Old Jan 11, 2008 | 12:56 PM
all-mtr-teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Move the VTEC point a little higher.</TD></TR></TABLE>
I was also wonder why vtec point was so low?
Old Jan 11, 2008 | 01:06 PM
4g hatch's Avatar
Default Re: Oem parts B18c with Pro1's (dinko)
i think that its crazy that the stock gsr cams made good power like that
Old Jan 11, 2008 | 01:14 PM
NipTucked's Avatar
Nice, hella nice power after vtec.
Old Jan 11, 2008 | 01:38 PM
.CUBISH.'s Avatar
Default Re: (NipTucked)
vtec is at 6k...the jump in power and trq down low is from the cold air
Old Jan 11, 2008 | 01:48 PM
.CUBISH.'s Avatar
Default Re: (.CUBISH.)
red=stock header
blue=ebay 4-1
keep in mind...the graph with the stock header it was 50-60 deg outside...today its about 75-80
Old Jan 11, 2008 | 02:03 PM
.CUBISH.'s Avatar
red=ebay header untuned
blue=ebay tuned
Old Jan 11, 2008 | 02:06 PM
mike-y's Avatar
nice!
very interesting regarding the headers too. was the car re-tuned with the eBay 4-1, or was it just bolted on?
I remember running a ported out stock header on a B18c1 a LONG time ago, and it made a surprising amount of power and had great throttle response.
Old Jan 11, 2008 | 02:14 PM
.CUBISH.'s Avatar
Default Re: (mike-y)
last graph i posted showed the ebay header tuned and untuned
Old Jan 11, 2008 | 02:47 PM
Del Sex's Avatar
Where's the dyno of the said RMF narrow?
And the ebay header only added 2 whp and lost you torque from the stock mani?
Old Jan 11, 2008 | 05:51 PM
mike-y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">last graph i posted showed the ebay header tuned and untuned</TD></TR></TABLE>
ah, got it. I must have been typing my post while you were posting the 2nd graph. Very nice numbers there.
Old Jan 11, 2008 | 11:53 PM
Rickdrizzle's Avatar
wow, those are some pretty decent results with the pro1's with stock/shitty header.
Old Jan 12, 2008 | 08:01 AM
MikeSarr_GSR's Avatar
Default Re: (Rickdrizzle)
no kidding - the inner diameter of the stock GSR header is like 1.75"
thanks for posting this - so how much do you charge for tuning
Old Jan 12, 2008 | 08:28 AM
ESP.net's Avatar
Default Re: (MikeSarr_GSR)
Nice comparisson! I 4 see... 200+ whp 2"runners, 2.5" collector, 2.5" exhaust system
Old Jan 12, 2008 | 01:23 PM
.CUBISH.'s Avatar
Default Re: (ESP.net)
pm me for tuning prices and info...
the ebay head lost some mid range and gained from 7.5-9k
only 2 peak, but 7-9 hp up top
i didnt get a chance to test the rmf yet..i cant run the dyno past 7pm weekdays...and not at all on weekends
Old Jan 12, 2008 | 06:39 PM
Del Sex's Avatar
i didnt get a chance to test the rmf yet..i cant run the dyno past 7pm weekdays...and not at all on weekends </TD></TR></TABLE>
Post it up Monday!
