y1 b16 gears into ys1 case with 99gsr gear set?
Old Jan 11, 2008 | 04:47 AM
92DAIntegraXSI's Avatar
Default y1 b16 gears into ys1 case with 99gsr gear set?
ok i picked up a y1 b16 cable trans from a buddy for dirt cheap. has a messed up reverse and possibly 3rd gear. basicly reverse wont engage because of the teeth messed up on first. in the car now i have a ys1 case with 99 gsr gear set. the case has been modified to accept a hydro lsd which i have yet to install. now will the gears from the y1 tranny work on the GSR counter and mainshaft? or are they to small? i kno the counter shaft itself will not work on the car because of my clutch. im just curious on the gear swapping. tried searching didnt get a str8 answear.
Modified by 92DAIntegraXSI at 3:45 PM 1/11/2008
Old Jan 11, 2008 | 05:35 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: y1 b16 gears into ys1 case with 99gsr gear set? (92DAIntegraXSI)
You should post this in tech/misc as well. There is more transmission expertise over there.
Old Jan 11, 2008 | 07:42 AM
Default Re: y1 b16 gears into ys1 case with 99gsr gear set? (Dogginator)
alright sounds good dogg thanx
ashb82
Transmission & Drivetrain
Aug 15, 2011 02:28 PM
beastsohc
Jan 18, 2009 05:08 AM
92DAIntegraXSI
Jan 14, 2008 07:11 AM
andyboy
Jul 20, 2004 09:26 AM
