b20vtec or lsvtec
Old Jan 10, 2008 | 11:29 PM
onelugshortofpimpin's Avatar
Default b20vtec or lsvtec
k i wanna start a new project for the summer and am lookin at these two for my chooses and hope to get some feed back on others which puts out more and which is more dd capible i will build properly i just want to know which has better power gains basicaly with out going turbo
Old Jan 11, 2008 | 04:36 PM
blkb18's Avatar
Default Re: b20vtec or lsvtec (onelugshortofpimpin)
Bigger is always better, it all depends on how much $ you are willing to part with. If $ isnt an object, I would go with Endynes talldeck stroker motor. 300hp, dd friendly. If money is a concern you can do a reliable ls vtec/b20 vtec for much less and get in the low 200 hp range.
Old Jan 11, 2008 | 04:41 PM
PyroProblem's Avatar
Default Re: b20vtec or lsvtec (blkb18)
B20..No replacement for displacement. Especially if your going all motor...
Old Jan 11, 2008 | 04:49 PM
VeeL_B20's Avatar
Well if you are looking for dd, both b20 and ls vtec are fine. If you are looking for a little more displacement, the b20 would be the better route to go. There's also a few topics on this subject in Honda-tech that has been brought up, so I would look around to see which setups would get you the best power gain. GOOD LUCK!!!
Old Jan 12, 2008 | 01:16 PM
RG400SmartTowel's Avatar
B20 is the way to go
carlossolorzano
Nov 22, 2010 07:29 AM
spies1602
Jan 13, 2008 09:02 AM
92integraVTECgsr
Sep 25, 2005 10:35 PM
SinCitiEK4
Sep 5, 2005 01:25 PM
twotimesfour
Nov 11, 2002 05:26 PM
