Swap Super Guys Come Here
Old Jan 10, 2008 | 09:50 PM
D16SohcVtec's Avatar
Default Swap Super Guys Come Here
Just got a EG shell and a bunch of EF parts laying around. I'm going to be swaping a b-series motor into the EG shell. I've never done a b-series swap before, therefore I don't really know anything about b-series parts etc. So if you swap masters could chime in it'd be great.
Anyway I have two parts that I need to know if I can reuse it or not since the b-series motor use to be in a CRX.
The swap came with Hasport mounts for an EF w/ cable tranny. Couple still usable?
The shift linkage for a b-series in a EF, still usable for an EG body?
Old Jan 10, 2008 | 10:59 PM
saywhat's Avatar
Default Re: Swap Super Guys Come Here (D16SohcVtec)
I think you might be out of luck trying to use the EF parts on the EG. But on the positive side you can use everything from the Integra and it will bolt right up, e.g.; Mounts, Linkage, Etc...
Old Jan 10, 2008 | 11:41 PM
smileycvc's Avatar
Default Re: Swap Super Guys Come Here (saywhat)
Pretty sure neither of those will work. You will hopefully have a hydro tranny now instead of cable.
Old Jan 11, 2008 | 05:29 AM
crazyguy's Avatar
first u need to get a new mounts for eg and it depends on if u have a b16 or b18c engine cause mount on driver side is slightly different. second of all , you will need a b series hydrolic tranny with 94 up and integra shift linkage and intermediate axle and cv axles
and also identify if it is a obd1 or obd0 engine swap and get the right ecu.
Old Jan 11, 2008 | 06:43 AM
Default Re: Swap Super Guys Come Here (crazyguy)
Thanks a lot guys I appreciate it. I knew about the cable tranny, so I'm going to sell that. And I guess the mounts and the linkage will have to go also.
The motor that's going to be going in is b16b CTR.
Old Jan 11, 2008 | 07:22 AM
RyanA's Avatar
Actually, just pay attention to the driver side mount "bracket" Make sure you get the 2 bolt or 3 bolt mount to match whatever cast iron bracket is on your engine. Keep in mind the older B series 2 bolt bracket has a different offset on the studs where the mount attaches so you will want to make sure to have an Integra or Del Sol cast iron bracket.
Old Jan 11, 2008 | 07:51 AM
sleepencivic's Avatar
Default Re: Swap Super Guys Come Here (RyanA)
you can use the cable tranny in a eg i have a Y1 in mine...get the ha-sport mounts and their cable to hydro conversion, get the hydro tranny axels and half-shaft and you will have to change the half shaft seal on the tranny very easy to do and your golden powertrain wise...you will have to convert the engine to obd1 get some obd1 injectors and dizzy and use the stock eg wire harness modified for the extra vtec wires along with a obd 1 ecu you can have the stock one reprogramed from http://www.phearable.net
Old Jan 11, 2008 | 01:05 PM
Default Re: Swap Super Guys Come Here (sleepencivic)
I see thanks for the input, no I'm going to steer away from a cable tranny. So then I guess I'm going to have a big yard sale on EF b-series parts.
Old Jan 14, 2008 | 06:15 AM
why the cable tranny works fine in the hydro car?
Old Jan 14, 2008 | 06:20 AM
BryanM.'s Avatar
Resident Gearhead
I think he doesn't want to do that much modding just.
Old Jan 14, 2008 | 09:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepencivic &raquo;</TD></TR><TR><TD CLASS="quote">why the cable tranny works fine in the hydro car? </TD></TR></TABLE>
I know it works, but when change from a hydro setup to a cable setup? I think it's kind of a useless mod trying to fit a cable tranny in the a car already equiped with hydro.
Old Jan 14, 2008 | 09:43 AM
but if you have a cable tranny
Old Jan 14, 2008 | 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepencivic &raquo;</TD></TR><TR><TD CLASS="quote">but if you have a cable tranny </TD></TR></TABLE>
Not much of an option with cable trannys anyway, I was going to do a cable to hydro conversion using the new innovative master cylinder if i decided to use an EF hatch instead. Overall, I'm not interested in that mod, GSR hydro tranny is what interests me the most right now.
Old Jan 14, 2008 | 02:01 PM
RyanA's Avatar
Yeah, he has a cable tranny. A weak, inferior, cable tranny. I'd stick with a hydro even if the cable is a large spline unit.
Old Jan 15, 2008 | 04:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">
I know it works, but when change from a hydro setup to a cable setup? I think it's kind of a useless mod trying to fit a cable tranny in the a car already equiped with hydro.</TD></TR></TABLE>
you use all the hydo parts its just an adapter on the slave that bolts on to the cable actuator for the clutch fork so its still is hydro its just a cable tranny
andytec-v
May 25, 2012 07:41 PM
96johnson
Jun 3, 2010 02:56 PM
iheartmycvc
Sep 15, 2008 12:43 PM
tealsvteceg
Mar 2, 2008 06:52 PM
92integraVTECgsr
Mar 1, 2007 12:33 AM
