Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
2008 Solo Rules up
Old Jan 10, 2008 | 08:00 PM
civexspeedy's Avatar
Default 2008 Solo Rules up
http://www.scca.com/documents/...2.pdf
looks like they cleared up the lateral members for sway bars
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Non-standard lateral members which connect between the brackets for the bar, including allowed strut bars per 14.2.G, are permitted.</TD></TR></TABLE>
Old Jan 11, 2008 | 05:30 AM
thisisntjared's Avatar
Default Re: 2008 Solo Rules up (civexspeedy)
nice! so that means i can run an asr subframe brace on my em1 in sts!!!
i think this year i am going to print it out and make it into a binder.
Modified by thisisntjared at 10:08 AM 1/11/2008
Old Jan 11, 2008 | 08:01 AM
SHG_Mike's Avatar
Default Re: 2008 Solo Rules up (thisisntjared)
i still dont get why a b16a2 from a si... cant be put in a 96-00 civic and run DSP. You can put a b18c5 in an integra LS and run DSP... makes no sense. Hate having to run SM with a b16 lol
Old Jan 11, 2008 | 09:57 AM
Default Re: 2008 Solo Rules up (SHG_Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHG_Mike &raquo;</TD></TR><TR><TD CLASS="quote">i still dont get why a b16a2 from a si... cant be put in a 96-00 civic and run DSP. You can put a b18c5 in an integra LS and run DSP... makes no sense. Hate having to run SM with a b16 lol</TD></TR></TABLE>its all the other factory options that allow it to stay in hs. i mean 2600 lbs is on the heavier side compared to all the other civics that can weigh considerably less with less hp. i agree that having a b16 in sm does kinda suck when the motor came from a car in the slowest class, but your flywheel alone will push you to dp or sm i think.
maybe you should have picked up a 99 and done a trim conversion.
Modified by thisisntjared at 2:21 PM 1/11/2008
Old Jan 11, 2008 | 10:44 AM
gabebauman's Avatar
Awesome...thanks.
Can someone please enlighten me on the engine swap criteria for Street Modified? It's kinda confusing. Example: You can have a gsr motor, (usdm or jdm) in your 99 civic coupe...yes or no?
Page 117:
1. Engine block must be a production unit manufactured and badged the same as the original standard or optional engine for that model. Badges that exist as marketing aliases for the manufacturer will be recognized as equivalents. Swaps involving makes related only at a corporate level are not recognized as equivalents. Models produced as a joint |venture between manufacturers may utilize any engine from any partner in the joint venture, provided that an engine from the desired manufacturer was a factory option in that particular model (e.g. Eagle Talon available originally with either a Mitsubishi or Chrysler engine, may use any motor from Chrysler or Mitsubishi). This allows engine blocks manufactured as production units for sale in other countries such as Japan or Germany.
Old Jan 11, 2008 | 11:48 AM
Default Re: 2008 Solo Rules up (gabebauman)
yes. but you cannot put an ls1 in your civic and remain in street mod.
Old Jan 11, 2008 | 11:59 AM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared &raquo;</TD></TR><TR><TD CLASS="quote">yes. but you cannot put an ls1 in your civic and remain in street mod.</TD></TR></TABLE>
That's what I thought...thanks for the input.
The civette would not run SM.
Modified by gabebauman at 3:48 PM 1/11/2008
Old Jan 11, 2008 | 12:15 PM
i would be pissed if it did
Old Jan 11, 2008 | 02:50 PM
SHG_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thisisntjared &raquo;</TD></TR><TR><TD CLASS="quote">its all the other factory options that allow it to stay in hs. i mean 2600 lbs is on the heavier side compared to all the other civics that can weigh considerably less with less hp. i agree that having a b16 in sm does kinda suck when the motor came from a car in the slowest class, but your flywheel alone will push you to dp or sm i think.
Modified by thisisntjared at 2:21 PM 1/11/2008</TD></TR></TABLE>
yea i know, so would the motor mounts and gutted rear... its just the idea. In all actuality i dont have much of an atvantage over a si. ah well... JRSC/4.9 FD/LSD will make me competitive in SM
Old Jan 11, 2008 | 04:24 PM
jeffhaut's Avatar
yea i know, so would the motor mounts and gutted rear... its just the idea. In all actuality i dont have much of an atvantage over a si. ah well... JRSC/4.9 FD/LSD will make me competitive in SM </TD></TR></TABLE>
youll need more than the blower im affraid, i run a supercharged integra in SM. i do ok locally, but when i go to the larger events i get my *** HANDED to me.
now squeeze some 275 on that bich, roll her down to minimum weight ( a fwd 1.8 SC car is 1990 lbs) and we're in buisness
Old Jan 11, 2008 | 04:29 PM
SHG_Mike's Avatar
Default Re: 2008 Solo Rules up (jeffhaut)
thats not true... the #1 FWD has a b18c5 NA.... he said a b16 with jrsc had much more low end... put a 4.9 on that... weeee, And yes 275's im on 205 v710's now. And i dont plan on doing that many big events yet. Its still a DD
Old Jan 11, 2008 | 05:22 PM
jeffhaut's Avatar
i didnt mean more power nothing better than a little grunt from our hondas with the help of a blower, i meant more than just the added power
rodney is the man. so is clemson hatch with his twin charger setup.
Old Jan 11, 2008 | 05:45 PM
SHG_Mike's Avatar
ah yes... you are correct... i would need to step to 275's
pics or info on said twincharged setup?
Old Jan 11, 2008 | 10:20 PM
jeffhaut's Avatar
https://honda-tech.com/zero...age=1
theres a new owner, but icant find any info
Old Jan 12, 2008 | 06:41 AM
SHG_Mike's Avatar
sick
roller3804
Jul 17, 2007 02:42 AM
Civicman86
Suspension & Brakes
Jun 12, 2007 07:30 PM
Mugen_DC2R
Oct 12, 2005 04:53 AM
hybrid901
Honda S2000
12
Aug 16, 2004 04:30 AM
Lo-Buck EF
12
Mar 17, 2003 06:27 PM
