Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness belts
Old Jan 10, 2008 | 07:15 PM
'95 BA8's Avatar
Default Harness belts
I'm looking into getting a 3 point harness belt for my car, I do not have a roll cage or a harness bar to mount them on, I did notice Corbeau has "bolt in" models, but int he pictures they don't show a way to bolt in the top one, its just a strap which leads me to the conclusion that it is designed for the harness bar, how would I bolt in that shoulder/top strap to the car without the harness bar?
Thank you.
Old Jan 10, 2008 | 08:11 PM
.:Made in OC:.'s Avatar
Default Re: Harness belts ('95 BA8)
The only safe way is a harness bar.
Old Jan 10, 2008 | 08:49 PM
dirty19's Avatar
Ridin Dirty in Cali
they might be bolted to the floor... I wouldnt recommend it though.
Old Jan 10, 2008 | 09:32 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Harness belts (dirty19)
What will you be using it for?
Old Jan 10, 2008 | 11:27 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirty19 &raquo;</TD></TR><TR><TD CLASS="quote">they might be bolted to the floor... I wouldnt recommend it though.</TD></TR></TABLE>
when the harness is bolted to the floor, or the rear seats/seat belts, in an accident since the belts are angled down they will pull you down in the chair which could break/hurt your back.
You're much better off using a stock seat belt then a 3point mounted to the floor. Not to mention a 3pt is a ball crusher.
Modified by liam821 at 12:59 AM 1/11/2008
Old Jan 11, 2008 | 02:45 AM
'95 BA8's Avatar
Default Re: Harness belts (liam821)
My oem seatbelts are in pretty bad shape.
I'm sure they aren't that safe.
I'm probably going to Auto-x in the future, I just don't wanna spend on some seat belts and have to replace them later...
But I don't know much about harness bars but what do you guys recommend then?
I know finding one for the Prelude is gonna be a PITA..
Old Jan 11, 2008 | 07:07 AM
Suspetise...
Actually, here's something neat: if your stock seatbelts are actually worn out and you suspect them to be unsafe, you can take the car into the dealer and they should replace them for free. Even if one dealer won't accept that, try around.
Old Jan 11, 2008 | 08:21 AM
liam821's Avatar
Default Re: Harness belts (Stinkycheezmonky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">Actually, here's something neat: if your stock seatbelts are actually worn out and you suspect them to be unsafe, you can take the car into the dealer and they should replace them for free. Even if one dealer won't accept that, try around.</TD></TR></TABLE>
Yeah ive heard this too. Most dealers will replace seat belts at no charge, even if the car is way out of warranty. They dont want you getting in an accident and killing yourself because of a bad seat belt.
Old Jan 11, 2008 | 10:22 AM
RSZero1's Avatar
this is very true - did that with my CRX just recently. As long as the belt has not been tampered with, bring it in to the service dept, they'll write it up, and order the part.
Once in, they'll swap it out. Done deal. Even though I will be mounting harnesses in my civic, I'm doing that same thing to it first, so I have fresh replacements if I need to put them back in later.
Old Jan 11, 2008 | 10:49 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Harness belts (RSZero1)
Honda seatbelts are lifetime warrenty!!!!!!!!!!!! as long as they haven't been tampered with.
Old Jan 11, 2008 | 12:02 PM
dirty19's Avatar
Ridin Dirty in Cali
I have seen some Eyebolts to the floor used for the over the shoulder belts.. however I would never use them because of this very reason.
Old Jan 11, 2008 | 01:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’95 BA8 &raquo;</TD></TR><TR><TD CLASS="quote">My oem seatbelts are in pretty bad shape.
I know finding one for the Prelude is gonna be a PITA..</TD></TR></TABLE>
Run a Sparco Harness bar.
Old Jan 11, 2008 | 03:26 PM
'95 BA8's Avatar
Default Re: Harness belts (.:Made in OC:.)
I only found them for the 5th gen 97+ I doubt those will fit my car, I guess I didn't look hard enough, I'll be going to Honda Monday and seeing what's up.
Old Jan 11, 2008 | 03:32 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’95 BA8 &raquo;</TD></TR><TR><TD CLASS="quote">I only found them for the 5th gen 97+ I doubt those will fit my car, I guess I didn't look hard enough, I'll be going to Honda Monday and seeing what's up. </TD></TR></TABLE>
Yep, you need to look harder...
Harness Guide Bar Range 46-3/4 to 49 inches Honda: Prelude (1992-1996) Price: $114.95
http://www.ioportracing.com/Me...=GB4R
email sparco, they can make one for you any day.
Old Jan 11, 2008 | 04:23 PM
Kamin's Avatar
im gonna go against the grain here and say harness' dont belong in cars without ROLLbars.
not just harness bars.
Old Jan 13, 2008 | 06:45 PM
'95 BA8's Avatar
Default Re: Harness belts (Kamin)
Okay, I've been doing some searching.
I found a website that sells "bolt in" roll cages for my Prelude, what do you guys think of them? Is it just as safe as a welded in rollcage would be?
I'm thinking it wouldn't since you'd have to put it together to get it in the car because fully built it won't go in through the door muchless the roof lol.
Old Jan 13, 2008 | 07:22 PM
Kamin's Avatar
you need a rollBAR not a CAGE
cages are for racecars and people who wear helmets
not for street cars.
Old Jan 13, 2008 | 07:37 PM
'95 BA8's Avatar
I plan to have the car somewhat trackable by the end of the year so I'll probably look into one in the future, hence my question.
Auto-xers wear helmets
Buttt where can I find a rollbar for my car then?
http://www.upgrademotoring.com...p.htm
Good place to call and get quotes?
Old Jan 13, 2008 | 08:11 PM
Kamin's Avatar
if the car is driven on the street, it doesnt get a cage. thats what im getting at.
and check for vendors who sell these two
http://www.kirkracing.com/
http://www.autopowerindustries.com
Old Jan 14, 2008 | 02:42 AM
'95 BA8's Avatar
ahhh, alright thank you so much
nick21
Jan 3, 2015 02:07 PM
jdmfreak1992
Honda Civic (2001 - 2005)
Jun 29, 2012 02:01 PM
Rudaluda
Welding / Fabrication
Apr 13, 2009 10:08 PM
climb_on
13
May 8, 2008 08:40 PM
g2b2
May 6, 2007 11:14 AM
