how does a GSR do with oil?
Old Jan 10, 2008 | 06:52 PM
vinhtendo's Avatar
Default how does a GSR do with oil?
can you guys tell me how your GSR does with the oil you put in, does it disappear? or is it still full? before your next oil change
Old Jan 10, 2008 | 09:53 PM
MrViet's Avatar
Default Re: how does a GSR do with oil? (vinhtendo)
wtheck? there's only 2 places ur oil's gonna go. out ur exhaust or on the ground cuz of leaks
Old Jan 10, 2008 | 10:23 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: how does a GSR do with oil? (MrViet)
i think he means if our gsr's burn oil, and yes most gsr's do burn oil, mine burns a lil under a half a quart every 800miles, if i were you id check my oil level often, why? how low were you on oil when you did your oil change??
Old Jan 10, 2008 | 10:54 PM
racebum's Avatar
Default Re: how does a GSR do with oil? (DOHCgarage919)
Mine burns next to none. I have this leak by the vtec though, need to fix it, right now i have to add nearly a quart at 3000 miles and change at 5000. It's leaking way more than burning.
Old Jan 10, 2008 | 10:55 PM
Default Re: how does a GSR do with oil? (idrivesideways)
Old Jan 10, 2008 | 11:06 PM
supracrx's Avatar
a GSR should be the same as any other car....if no leaks, and no major burning i think in btwn oil changes maybe 1/2 quart to a quart is acceptable....
my integra needed about little less then half a quart of oil in btwn 3000 mile oil change. but i know my rear seal is leaking a little, and oil pan....
Old Jan 11, 2008 | 12:46 AM
mike5809's Avatar
Default Re: (supracrx)
About 1/4-1/2 quart or a bit less every 3000 miles or so. 96,xxx miles now
Modified by mike5809 at 12:26 PM 1/11/2008
Old Jan 11, 2008 | 08:01 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (mike5809)
It depends on mileage and condition of the engine.
Our '94 GS-R didn't leak any oil at all for the first 100K miles. When it was in the 130-160K mileage range, it was using a quart every 1200 miles. Now it has 171K miles and burns a quart of oil every 600 miles or so. It's not leaking oil anywhere, all consumption. I'm sure it needs to be re-ringed or whatever, but it's a lot cheaper to just keep an eye on the oil level and add oil as needed, than to spend several grand on re-ringing the engine.
highwhey
Nov 11, 2010 05:53 AM
07FG2
Honda Civic (2006 - 2015)
41
Feb 9, 2009 05:58 PM
vinuneuro
Mar 15, 2005 04:41 PM
digitalayon
Mar 13, 2005 07:55 AM
matix
Apr 18, 2004 09:32 AM
