GSR TURBO SWAP (MERCED 95340)
Old Jan 10, 2008 | 04:00 PM
ZLboosted_EG's Avatar
Default GSR TURBO SWAP (MERCED 95340)
I'm selling my B-series turbo swap
96 GSR bottom block:
Crower rods
JE pisotns 9:1
Golden Eagle sleeves
new water pump, oil pump, tensioner, t/belt
CTR N1 pulley
obd2 alternator
95 B16A3 head (Del SOl)
Dizzy (new oem cap, rotor, wires plugs)
new fuel filter
3 angle valve job
SKunk2 valve springs
GSR cams
ITR manifold
GSR throttle body
880 cc Precision injectors
Hayame fuel rail (red) with steel braided line
Hayame Cam gears (red)
B&M fuel pressure regulator
milled down for even mating surface
95 GSR tranny:
Stage 1 pressure plate
Six puck clutch
new oem throw out and pilot bearings
Lightened oem flywheel
Turbo:
Ram horn manifold
Turbonetics wastegate
92-00 civic Greddy piping
Graddy Intercooler
XS power dual horn blow off valve
all couplers
t-bolt clamps
t3/t4 turbo .57 trim
down pipe and all
swap will also come with:
axles, half shaft, shift linkage, ecu, boost controller, turbo timer, boost gauge
Also selling my hatch. Car is ready for this swap just drop in and tune. Car will be reassembled before pick up. Just got painted less than a month ago (engine bay, inside rear, outside and all. Moldings, handles, everything came off. painted the right way. lips, moldings, handles, skirts, mirror, wing all painted)
96 civic hatch CX
clean title
completely painted inside and out Rally Red
SI front seats
Full GSR suspension with rear disc brakes
KYB shocks
Skunk2 coilovers
Omni front and rear camber kit
ASR subframe silver BNIB
Blox lower control arms silver BNIB
front and rear upper billet strut bars
Voodoo vacuum box
Auto meter tach, boost gauge, a/f, oil pressure gauges with gauge pod
Si cluster
Greddy boost controller and turbo timer
obd2 to obd1 jumper with chipped p28
wiring harness is wired for injector with box and all
00 si front end
fog lights (yellow lens)
hid conversion headlights (toyota parts)
Spoon replica mirrors and wing
front and rear lips
GSR shift linkage
$4500 obo for the turbo swap
or $8500 obo for the car and swap.
if really interested pm me or call me
209-631-4371 Luis
Pics will be up this weekend
Old Jan 11, 2008 | 12:54 PM
Default Re: GSR TURBO SWAP (ZLboosted_EG)
BUMP
pinkybuilt22
Jan 4, 2011 08:42 PM
pinkybuilt22
Dec 22, 2010 07:56 PM
ZLboosted_EG
Jan 21, 2008 05:39 PM
ZLboosted_EG
Jan 21, 2008 01:58 PM
ZLboosted_EG
Jan 13, 2008 09:28 PM
