b18c with b18b crank help????
Old Jan 10, 2008 | 03:53 PM
killah1's Avatar
Default b18c with b18b crank help????
ok heres my problem i have a good gsr block clean but it spun a bearing took it all apart an it looks really bad its crank is gone
in the mean time i lost the bridge cap that holds the main bearins in place
i was thinking of using my ls crank rods (balanced) on the gsr an was wondering if i could just use the ls main bearing caps on the gsr would it still work???
need some help please ???
Old Jan 10, 2008 | 04:03 PM
Schister66's Avatar
Man U FTW
The GSR block w/ an LS crank is a fairly common occurence. You use all of the GSR caps and mains along with the LS crank AND LS rods. That'll about do it...
Old Jan 10, 2008 | 04:42 PM
killah1's Avatar
true but the thing is i lost thre main bridge caps for the gsr can i run the ls main caps
Old Jan 10, 2008 | 04:49 PM
Schister66's Avatar
Man U FTW
Default Re: (killah1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killah1 &raquo;</TD></TR><TR><TD CLASS="quote">true but the thing is i lost thre main bridge caps for the gsr can i run the ls main caps</TD></TR></TABLE>
Not sure, but i'm sure someone does. If nobody answers, check the Hybrid forum because i'm sure someone there knows.
Old Jan 10, 2008 | 10:03 PM
killah1's Avatar
some one must know
Old Jan 17, 2008 | 01:49 PM
hondahippy's Avatar
Default Re: b18c with b18b crank help???? (killah1)
i'm no expert but i'd have to think that if you could put the LS crank into the B18C block then they would have the same size mains,,, and i believe you can run a gsr girdle and all that jazz on an LS, no problems i can see. anyone else?
Old Jan 17, 2008 | 02:24 PM
doood's Avatar
been there done that
if you use the ls main caps you need to get the journals align bored and honed then use oversized bearings, which isnt really recommended.
Old Jan 17, 2008 | 04:12 PM
pdiggitydogg's Avatar
it needs to be line honed regardless, becuase any main cap wont match up like the originals
personally, i dont see that it would be too much of a problem, running fatter bearings
acura_b18c1
May 11, 2011 12:46 PM
egboy94
Feb 20, 2009 05:23 PM
killah1
Jan 11, 2008 07:29 PM
ferio 95
Oct 7, 2004 08:58 AM
MTP04
Jan 2, 2003 04:30 PM
