mismatch rotors
Old Jan 10, 2008 | 02:43 PM
onemore's Avatar
Default mismatch rotors
I purchased a rear brake setup from a 91 crx si. The rear rotors are slotted. I really don't what to spend the money for slotted rotors for the front. I was just going to throw some brembo blanks on the front. Do you guys think I will run into a braking problems because of the rotors being mismatch.
Thanks
Old Jan 10, 2008 | 03:23 PM
LIMITLESS22's Avatar
Default Re: mismatch rotors (onemore)
No you'll be fine. The slotted rotors just help the gasses/heat escape from rotor surface. Thats the only reason they improve braking.
However if you upgraded your brakes from drum to disc then I would replace the master cylinder and proportioning valve so the system can perform the way it was designed.
Old Jan 10, 2008 | 03:30 PM
onemore's Avatar
yeah I got the proportioning valve from a 91 si and I'm going to go with the ex master and booster
Old Jan 10, 2008 | 03:49 PM
Default Re: (onemore)
Then you're good.
Old Jan 10, 2008 | 05:02 PM
ef9itb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onemore &raquo;</TD></TR><TR><TD CLASS="quote">yeah I got the proportioning valve from a 91 si and I'm going to go with the ex master and booster</TD></TR></TABLE>
yup your good, cause without the proportioning valve it wouldnt work correct.
redtrumpet67
Suspension & Brakes
Jun 2, 2015 03:43 PM
Kidnkorner
Dec 7, 2009 03:06 PM
jacoop86
Feb 3, 2006 11:00 PM
esteen2
69
Jan 5, 2006 03:40 PM
tcwcrxhf
May 6, 2005 09:46 AM
