crx si
Old Jan 10, 2008 | 02:30 PM
spray_bombed's Avatar
Default crx si
hey guys...im gonna start off by saying im more of a ek/cb guy.....new to crx's....anyway I found a 88 si...for $800 (from a friend)...has a zc (soch) motor with the stock si tranny....its a mint car (physically) but doesnt run...the kid had it last year when we were in high school and it ran for about 2 weeks when he bough it....then one day it got to normal op. temp and just died and hasnt ran since late 06....when they swapped it they used the stock computer(which i think that is where to the problem lies)....but anyways I wanted to know if the soch zc is a decent platform to build up and are parts become hard to find for these ef crx's...thanks alot
Old Jan 10, 2008 | 02:35 PM
GI8U2racing's Avatar
Default Re: crx si (spray_bombed)
Sounds like a good deal. I'd check the ignition coil, I had mine die right in the middle of pulling out of a parking lot. You can fix up the ZC or swap in a B-series and have a fun little car for quite a steal. There is no shortage of CRX parts, that's for sure. Plus, they are the lightest "swap'able " Honda there is. I sure love mine.
Old Jan 10, 2008 | 03:48 PM
wiZCo's Avatar
Stouts 'n' Scotch
Yeah, go through the common checks, give it a tuneup, test the dizzy and main relay. The stock PM6 (Si) ECU will work just fine with any OBD0 ZC, so there shouldn't be a problem there.
Old Jan 10, 2008 | 03:54 PM
whiteknightef's Avatar
FIRST:
the stock ecu is the same ecu as they use on the zc but different red line/ fuel cut off.
SECOND:
The sohc zc is the same motor as the stock crx si d16a6, slight cam shaft lobe differences. Parts are the same as the a6.
THIRD:
If the car is mechanical and physically sound other than not running, this is a great deal and a good project for you. Just remember once you buy a crx you are hooked for life!
FOURTH:
check the normal reasons that a car doesnt run! GET a service manual!
Old Jan 10, 2008 | 04:10 PM
thanks for the inputs guys...I appreciate it
91GEDHATCH
Jul 15, 2014 06:05 AM
1994rm250
Classic Hondas
Dec 1, 2007 03:47 AM
TheRoad64
Mar 5, 2007 10:43 AM
phoQ
Feb 18, 2005 11:54 PM
IraceAcrx
Mar 4, 2004 06:03 PM
