at idle motor tends to shake alot and why???
Old Jan 10, 2008 | 01:41 PM
mynameizstitch's Avatar
Default at idle motor tends to shake alot and why???
ok the car is a 1998 with about 150k miles on it. car runs fine but when im at a complete stop and just idling the motor tends to shake a lot. what can be the cause of this? maybe a bad motor mount?. it seems to shake most on the driver side motor mounts next to the cam gears but that mount looks fine to me though so im stuck. (this car is not used to race its only a commuter and its an automatic so it has no abusing to it) any help or suggestions will be appreicated.
Old Jan 10, 2008 | 01:48 PM
Keno20's Avatar
Default Re: at idle motor tends to shake alot and why??? (mynameizstitch)
Could be mounts. Could also be the problem with the cylinder as in your other thread too though. My girlfriends car was running on 3 cylinders and ran fine but when idling it ran like a tractor shaking all over the show
Old Jan 10, 2008 | 01:52 PM
will it hasnt been shaking until like 5k miles ago and the cylinder misfire came on like 10k miles ago so im stoked and dont know whats wrong
Old Jan 10, 2008 | 01:55 PM
Keno20's Avatar
Default Re: (mynameizstitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mynameizstitch &raquo;</TD></TR><TR><TD CLASS="quote">will it hasnt been shaking until like 5k miles ago and the cylinder misfire came on like 10k miles ago so im stoked and dont know whats wrong</TD></TR></TABLE>
I still wouldn't rule it out. The ecu may have picked up the problem before it got as bad as causing the shaking. Just a thought though...
C_H_A_D
Apr 14, 2005 02:10 PM
216.226.142.95:27016
Aug 22, 2003 06:29 PM
bearboy80
Jul 9, 2003 01:49 PM
onyx00
Sep 27, 2002 12:39 PM
