cel throwing a misfire how to fix???
Old Jan 10, 2008 | 01:38 PM
mynameizstitch's Avatar
Default cel throwing a misfire how to fix???
ok 1998 integra throwing a cylinder misfire on the check engine light. i already changed the spark plugs, spark plug wires, cap rotors and its still not fixed. anyone know how i can get this fixed? (ecu was reset after these new installs and it went away but came back after like 150 miles)
Old Jan 10, 2008 | 01:42 PM
Keno20's Avatar
Default Re: cel throwing a misfire how to fix??? (mynameizstitch)
Have you reset the ecu after doing the work?
Old Jan 10, 2008 | 01:43 PM
yes ecu was reset and then it went away but after like 150 miles it came back with the same cel
Old Jan 10, 2008 | 01:49 PM
all-mtr-teg's Avatar
Default Re: (mynameizstitch)
do a compression test, i had bad rings which made my cylinder 1 misfire every now and then
Old Jan 10, 2008 | 01:50 PM
Keno20's Avatar
When you replaced the plugs were they as dirty as a hooker? Check the replacement plugs and see if they're now dirty as well.
Old Jan 10, 2008 | 02:05 PM
EvilPinkEye's Avatar
Default Re: (Keno20)
if all else fails...check the dizzy internals (forgot the name) and the timing belt pulley drive..check the teeth..as i had one missing once..
did the trick that trick the ecu splices to pairs of wires at the ecu plug.
Here you go...
http://technet.ff-squad.com/ckftrick.htm
Old Jan 10, 2008 | 02:27 PM
when i replaced the plugs they were fine. i guess ima have to do a compression test. i would figure nothing is wrong with the motor since its an automatic and not driven very hard at all
Old Jan 10, 2008 | 04:03 PM
GRAF-FITI's Avatar
* B A N N E D *
all this **** about distributor and compression test is a waste of your time
compression issues are almost impossible to cause a misfire
internal ditributor issues (coil, module) will affect more than 1 cylinder
get some good injector cleaner....or if you really want to be smart pay for a full injector flush/cleansing...that's where you should be focusing your efforts
Old Jan 10, 2008 | 04:19 PM
Keno20's Avatar
You should also make mention of the content of your other thread as I believe it is relevant, i.e. the shaking at idle. This points to the engine running on limited cylinders.
When you did all the work are you positive you replaced everything correctly? e.g spark plug leads to the dizzy in the correct order? Im sure you did but just checking as a part time mechanic friend of mine transposed 2 leads cos he didnt have them in the correct order...
Old Jan 10, 2008 | 04:59 PM
Default Re: (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">all this **** about distributor and compression test is a waste of your time
get some good injector cleaner....or if you really want to be smart pay for a full injector flush/cleansing...that's where you should be focusing your efforts</TD></TR></TABLE>
Good point...
Also reminds me to get the injectors cleaned or replaced, as my motors shakes a tad.
Old Jan 10, 2008 | 06:53 PM
goota's Avatar
I just had this problem too.
Most Likely its your injectors. you said you dont run your car hard, youve probably built up alot of carbon in your engine.
Anyways, run some seafoam through the brake booster line into your Intake Manifold, follow the instructions on the seafoam site, I used about 1/2 a can. I got rid of the code and it runs way better now too.
the brake booster line is risky but it is also the best option. Its cheap and it works. Just remember to let it suck up the seafoam slowwwwwwwwwwwwwwwwwwly.
Old Jan 11, 2008 | 06:45 AM
thanks alot guys i kind of figured it was the injectors also.
Old Feb 6, 2008 | 11:34 AM
honda_nation's Avatar
Could be just wires to the injectors too. squeeze and shake the wires around the injectors when the engines running and see if you can make it misfire. It happened with my 98 CR-V.
eflove
Jul 14, 2008 04:47 AM
sickofitall1113
Jul 31, 2007 12:47 PM
LFA Squad :: iTO
Jun 6, 2006 02:43 PM
bullz
Jul 15, 2002 10:19 PM
