Identifying by B16A... Please help!
Old Jan 10, 2008 | 12:36 PM
h22xcivic's Avatar
Default Identifying by B16A... Please help!
Im getting a JDM B16A and im trying to figure out what it came out of. is there a way to check if its a 1st, 2nd or 3rd gen? i dont want to be stuck with a 1st gen when i paid for the 2nd. you never know what your going to get.
I seen head codes for the d series in the FAQ's. is there one for the b series?
Old Jan 10, 2008 | 12:40 PM
1jdmek's Avatar
Default Re: Identifying by B16A... Please help! (h22xcivic)
yes it says the year on the head....
Old Jan 10, 2008 | 12:41 PM
1jdmek's Avatar
Default Re: Identifying by B16A... Please help! (1jdmek)
there should be four stamps i believe and the far left or right is the year of it
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22xcivic &raquo;</TD></TR><TR><TD CLASS="quote">Im getting a JDM B16A and im trying to figure out what it came out of. is there a way to check if its a 1st, 2nd or 3rd gen? i dont want to be stuck with a 1st gen when i paid for the 2nd. you never know what your going to get.
I seen head codes for the d series in the FAQ's. is there one for the b series? </TD></TR></TABLE>
Yes there is a year stamped on the cylinder head above the exhaust ports on the B16A head. It looks like a 9/? with the "?" being the the other part of the year.
Example? If the engine was manufactured in 92 the stamp wpuld look like 9/2, etc. etc.
The thing is that sometimes a year stamp or 9/1 means the engine was made in 1991, but is actually still a "1992" model engine, or "second-gen" engine.
If the stamp says 8/9 no doubt it's a first-gen, but if it's 9/0 it gets tricky because it could be first or secnd gen because in Japan their 1991 model was an EG, and OBD1 "second-gen."
You can also ID the engine by it's injectors and the grey distributor plugs.
I'll find a pic of the head stamp code.
Old Jan 10, 2008 | 12:43 PM
h22xcivic's Avatar
Default Re: Identifying by B16A... Please help! (B18C5-EH2)
WOW THANKS!!! I will look for it! pics would be nice also. please post when you have time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
I'll find a pic of the head stamp code.</TD></TR></TABLE>
Old Jan 10, 2008 | 12:57 PM
B18C5-EH2's Avatar
Former Moderator
Loved
This is from my 1988 D16A6 head, but the exact same type stamp is used on the B series as well - it's the one on the right in the pic:
Old Jan 10, 2008 | 01:27 PM
VRD^sam's Avatar
Old Jan 10, 2008 | 04:32 PM
h22xcivic's Avatar
Again thanks!
Honda-Tech Members FTW!!!!
is there a way to see what chassis it came out from?
Old Jan 10, 2008 | 04:36 PM
BlueIntegraBoy's Avatar
Another way to spot a 1st gen is if it reads PGM-FI on the intake manifold like so...
2nd Gen and on will just have a couple of lines like so...
Old Jan 10, 2008 | 07:45 PM
h22xcivic's Avatar
Default Re: Identifying by B16A... Please help! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Another way to spot a 1st gen is if it reads PGM-FI on the intake manifold like so...
Now i know what to look for thanks alot guys!!!
Old Jan 14, 2008 | 05:56 AM
sohc1200cc's Avatar
the safest way is to check the dizzy..
Old Jan 14, 2008 | 06:09 AM
pdiggitydogg's Avatar
^Why would anyone want to base where an engine came out of on a part that is removed by 3 bolts? Its far too easy and far to common of an item to replace.
As stated, the best way is by the year that is stamped onto the head. "( 9 | x )"
The year alone is good enough to tell you the chassis, if it is usdm.
siopau
May 13, 2011 08:21 PM
civic_sir94
Jul 13, 2008 02:37 PM
raene
15
May 27, 2006 09:19 AM
EGinNY
Oct 31, 2004 01:05 PM
sol2nr
Apr 13, 2004 11:07 PM
