old gas
Old Jan 10, 2008 | 11:42 AM
jdmcoupeEJ1's Avatar
Default old gas
need help...what is the best way to take out old gas thats been sitting of hella long?
Old Jan 10, 2008 | 11:46 AM
Padawan's Avatar
Darth ModerVader
Default Re: old gas (jdmcoupeEJ1)
How much is in the tank?
Old Jan 10, 2008 | 12:05 PM
pat92si's Avatar
Default Re: old gas (Padawan)
You can either drop the tank and be careful if there isn't too much fuel in it, or you can try to syphen the gasoline out with a hose of some sort.
Old Jan 10, 2008 | 05:13 PM
theres a liittle more than 1/2 in the tank
Old Jan 10, 2008 | 05:24 PM
slow_cx's Avatar
Default Re: (jdmcoupeEJ1)
I hear fire works well.. But don't find out for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pat92si &raquo;</TD></TR><TR><TD CLASS="quote">You can either drop the tank and be careful if there isn't too much fuel in it, or you can try to syphen the gasoline out with a hose of some sort.</TD></TR></TABLE>
Don't most newer tanks have a screen or a block for that?
Old Jan 10, 2008 | 05:26 PM
abusedhusband's Avatar
Default Re: (slow_cx)
does it have a drain bolt.
Old Jan 10, 2008 | 05:32 PM
Syndacate's Avatar
Default Re: (abusedhusband)
Siphon it out.
Works well - I do it all the time.
Old Jan 10, 2008 | 05:34 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Syndacate)
Siphon it out, refill with fresh.
How old is it?
Old Jan 10, 2008 | 06:57 PM
A_Rotary_Guy's Avatar
A lot of the new vehicles have a screen so that you can't siphon it out. I do know that some manufacturers put drain plugs in the middle of the gas tank on the bottom for such occasions, but I believe this isn't used anymore because of the area around the plug rusting out. The only way to get the gas out of the tank is really to drop it and pour it out. Also, many of the new gas tanks are plastic now because of the problems vehicles used to have with gas tanks rusting out. But yea, how old was the gas? Usually after sitting for a month or so causes it to go bad, especially if it's sitting in an open container.
Old Jan 11, 2008 | 12:27 AM
the gas in the car is more than 2 years old
Old Jan 11, 2008 | 12:28 AM
it's in a 95 civic i havent got under the car to see if theres a plug
Old Jan 11, 2008 | 06:52 AM
afstvx's Avatar
take the cover for the fuel pump off under your rear seat. then syphone it out through there really easy. i actully used a wet/dry vaccum and just sucked the gas out from there. maybenot he safest thing but it worked. you might need to remove you fuel pump as well. but this is a much easier option the dropping the gas tank. and gas goes bad after 3-6 months depending on the make of gasoline.
Old Jan 11, 2008 | 07:12 AM
Ek Forever y0!
Default Re: (afstvx)
I want to say there's a drain plug on the fuel tank. I'm 90% positive.
Old Jan 11, 2008 | 07:21 AM
alacard's Avatar
There is a drain plug (atleast on 96-00 civics), but the plug is covered in some kind of anti-rust type retardant from the factory which tends to come off when you unscrew the bolt. I'm not positive, but I doubt it is a good thing for that material to come off and expose bare metal. I would do it the way afstvx suggested if you can't get a hose through the gas cap way.
Edit: I didn't make this clear: afstvx's suggestion.. minus the vacuum. Just use your mouth to syphon it
Modified by alacard at 5:03 PM 1/11/2008
Old Jan 11, 2008 | 09:52 AM
neocrynym's Avatar
Default Re: (alacard)
Your 95 Civic's gas tank has a drain on its bottom-rear. Jack up the front of the car, put an oil pan under the drain, undo the bolt, and drain away.
Old Jan 11, 2008 | 10:56 AM
Frickr's Avatar
Default Re: (neocrynym)
as long as if the fuel isnt dirty, just go and top off the tank, the new gas will mix with the old, may not be the best, but it will work till you finish off the tank. i had an old pickup that had been sitting for almost 10 years in my back yard with a blown motor, when i got a new motor for it, i used the gas that had been sitting in the tank. ran a little rough but wasnt to bad, just change your fuel filter after that tank of gas, wont have a problem. with gas being like gold now days, why waste it? and do you even have a safe place to dispose of it?? the only thing you have to worry about is having water in your tank.
Old Jan 11, 2008 | 01:45 PM
MoreBoost!'s Avatar
Default Re: (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr &raquo;</TD></TR><TR><TD CLASS="quote">as long as if the fuel isnt dirty, just go and top off the tank, the new gas will mix with the old, may not be the best, but it will work till you finish off the tank. i had an old pickup that had been sitting for almost 10 years in my back yard with a blown motor, when i got a new motor for it, i used the gas that had been sitting in the tank. ran a little rough but wasnt to bad, just change your fuel filter after that tank of gas, wont have a problem. with gas being like gold now days, why waste it? and do you even have a safe place to dispose of it?? the only thing you have to worry about is having water in your tank.</TD></TR></TABLE>
i agree if there no water or rust in the tank just mix it with new gas.. i did n works fine i still have about 10 gas containers from years ago in my shed, when we had gas shortage around my area
Old Jan 11, 2008 | 01:50 PM
andoxviii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afstvx &raquo;</TD></TR><TR><TD CLASS="quote">i actully used a wet/dry vaccum and just sucked the gas out from there. maybenot he safest thing but it worked. </TD></TR></TABLE>
Oh man...MAYBE not
Even the smallest spark inside that vacuum will blow up if you're sucking gasoline. I bet the user's manual for the vacuum will even warn you not to suck up flammable fluids.
I believe mythbusters tested this out, as well...
Old Jan 11, 2008 | 05:40 PM
thanks for everyones i appreciate everyones comments...i got i done i just opened up the drain plug from the bottom took most of it out then mixed it with the new gas
Baodalazi
12
Mar 24, 2007 07:59 AM
npor
Dec 7, 2006 09:19 PM
Red_Si
Oct 27, 2006 11:49 AM
litterbox
28
Nov 4, 2005 07:36 AM
adaml2nv
Jun 6, 2004 04:50 AM
