Kinda lost in my ls/vtec
Old Jan 10, 2008 | 09:02 AM
sixtodc4's Avatar
Default Kinda lost in my ls/vtec
i just did a ls/vtec conversion a couple of days ago. i cant even here vtec on my ride after i past 5rpm? Im still running a stock ls ecu ?? what ecu can i use, i have a 2001 integra ls.. help plz
Old Jan 10, 2008 | 09:24 AM
rocketrex's Avatar
gsr ecu is ur best choice...ur not going to get vtec with a ls ecu because vtec is not programed into it....best thing to do is search on here and see what best ecu to use...i have a gsr chipped in my ls/vtec
Old Jan 10, 2008 | 09:55 AM
mach0's Avatar
Default Re: Kinda lost in my ls/vtec (sixtodc4)
wtf..
Old Jan 10, 2008 | 10:23 AM
SkaiWu's Avatar
Default Re: Kinda lost in my ls/vtec (mach0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mach0 &raquo;</TD></TR><TR><TD CLASS="quote">wtf..</TD></TR></TABLE>
2nd poster already gave the answer correct yep
Old Jan 10, 2008 | 11:15 AM
DA_9's Avatar
GSR ECU WITH CHIP AND FULL TUNE OTHERWISE ITLL RUN LIKE ****.
Old Jan 10, 2008 | 11:18 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
wow u did an ls vtec but didnt know you needed a vtec ecu??? anyways get a p28 chipped ecu and a tune and you shud be set or gsr ecu...
Old Jan 10, 2008 | 01:06 PM
jdmjunkie8's Avatar
get a gsr ecu and hondata, get the most outta that motor.
Old Jan 10, 2008 | 01:44 PM
yarara0825's Avatar
Default Re: Kinda lost in my ls/vtec (jdmjunkie8)
wow.
get a gsr or p28 ecu then get it tune and hondata etc.
Old Jan 10, 2008 | 01:46 PM
VRD^sam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixtodc4 &raquo;</TD></TR><TR><TD CLASS="quote">i just did a ls/vtec conversion a couple of days ago.
Im still running a stock ls ecu ?? </TD></TR></TABLE>
rofl, you'll need a vtec ecu, lol.
Old Jan 11, 2008 | 08:51 AM
96lsvtec18's Avatar
Default Re: (rocketrex)
yo man your not gonna hear vtec with a ls ecu... your in a 2001 integra hmmm
i would get a step down harness for an obd1 ecu and get a chipped p28 and you will def love your car after that..but you wont pass inspection so keep that ls ecu for when u need inspection
You did a ls vtec swap.... Do you have gsr oil pump water pump timing belt??
If you dont your gonna blow your motor from not getting enough oil and water and have timing problems
Timing you have to move the distributor back like 5 degrees
Old Jan 11, 2008 | 02:16 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (96lsvtec18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96lsvtec18 &raquo;</TD></TR><TR><TD CLASS="quote">You did a ls vtec swap.... Do you have gsr oil pump water pump timing belt??
If you dont your gonna blow your motor from not getting enough oil and water and have timing problems</TD></TR></TABLE>
O rly .. ?
Old Jan 11, 2008 | 02:36 PM
yc_dc4mar's Avatar
Default Re: (CleanLikeJdm)
94-integra-ls
Mar 23, 2008 04:26 PM
egzo04
Aug 25, 2007 10:46 AM
Dc2 Joe
May 23, 2007 01:03 PM
JDMdamian95
Nov 1, 2006 03:11 PM
bboysake
Jun 20, 2006 11:36 PM
