all right...im starting a back up plan B.
Old Jan 10, 2008 | 07:21 AM
pkolaboy's Avatar
Default all right...im starting a back up plan B.
so if this whole rod bearing **** does not work with my h23...im really thinking about getting a swap... more likely a h22... (serious this time..) what is the estimate for dropping an h22? is it fairly easy?... give me all the help u can get...
Old Jan 10, 2008 | 08:01 AM
Acidcrakker's Avatar
Default Re: all right...im starting a back up plan B. (pkolaboy)
SEARCH BUTTON
It will be your new best friend. Ive given out handfuls of info on doing the swap, as well as doing it.
Search my screen name and there should be tons of threads.
Old Jan 10, 2008 | 08:11 AM
cb7tougeracer's Avatar
Default Re: all right...im starting a back up plan B. (Acidcrakker)
cost for a good one swapped in if you do the work around 2,000 the motor and crap starts around 1,000-1,800 then minor things for the swap if i were you get a new clutch while you got it out
Old Jan 10, 2008 | 05:02 PM
Default Re: all right...im starting a back up plan B. (cb7tougeracer)
I originally thought that my swap was going to run about 1500 bucks.....LOL, what a joke was that. I hit 3 grand easy. Once I started reliazing that having the right tools for the job made it easier, they started to add up. Plus all the little nickle and dime **** really added up.
pkrls
Oct 25, 2009 06:49 PM
Dav94Lx
Feb 16, 2008 06:56 AM
ge_itr
Dec 18, 2006 06:40 PM
M1SCO15
10
Oct 20, 2006 08:53 PM
4 Dr Swap It
Mar 14, 2003 05:42 PM
