Code 2 with P72 ECU
Old Jan 10, 2008 | 03:44 AM
mrchris1979's Avatar
Default Code 2 with P72 ECU
Just starting to break in my rebuilt GSR motor. I'm using Rywire's conversion harness along with a stock p72 ECU. I also have the CEL switch hooked up with the Rywire harness. It's a feature that lets me check the codes via the CEL in the cluster. Strange thing is that the CEL does not come on at all but when I turn the switch on, the CEL will blink two times (code 2). I have already reset the ECU. The code will go away for a while and then just reappear again. This only happens when I turn the switch on however. Car runs fine but just not sure what is causing this code 2. I've looked at my Integra and CRX manual and code 2 is not listed. Just checking to see if anyone else has had this problem.
Old Jan 10, 2008 | 04:14 AM
I CRX I's Avatar
when the car is on and running, without the jumper wire grounded, do you have a CEL? that wire should not be grounded unless you have a CEL. if it has no CEL when the wire is not grounded then you should be fine.
Old Jan 10, 2008 | 09:21 AM
424racer's Avatar
Default Re: Code 2 with P72 ECU (mrchris1979)
maybe this will help you.
code #2
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B"
defective circuit or unplugged / defective sensor
code #20
90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector
2x0
May 15, 2018 04:35 AM
91efbluehatch
21
May 30, 2017 10:19 AM
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
1sikhatch
Jan 31, 2010 09:06 AM
esca
Oct 14, 2004 06:34 PM
