Honda S2000 Honda S2000
hi boosted sk2's using for fuel set up?
Old Jan 9, 2008 | 11:51 PM
vtecnitian's Avatar
Default what are the high boost sk2's using for fuel set up?
where can i find 1600cc injectors that fit the s2000?
and what are you guys doing about the fuel pump are you guys going dual pumps or external and if you guys are going external what are you guys doing about the tank since is plastic?
Modified by vtecnitian at 1:20 AM 1/10/2008
Old Jan 10, 2008 | 06:30 AM
blkturbos2k's Avatar
Default Re: what are the high boost sk2's using for fuel set up? (vtecnitian)
Why do you need 1600cc injectors? I have 1000cc and still have fuel
Old Jan 11, 2008 | 12:05 AM
vtecnitian's Avatar
Default Re: what are the high boost sk2's using for fuel set up? (blkturbos2k)
with the set up i have and what iam planning boost and my horsepower goal by my calculations 1000cc injectors would be to small. plus i rather have more fuel than i need.
Old Jan 11, 2008 | 04:46 AM
Are you going to run 40lbs? i have been running 26lbs on a 63mm turbo @ 85% injector duty. And thats with a small 255 pump
Old Jan 12, 2008 | 02:41 PM
vtecnitian's Avatar
iam planning 30-35psi or more on a 70mm turbo and don't want 85% duty cycle. all i want to know who makes them not y i want them lol.
Old Jan 12, 2008 | 03:18 PM
papa5murf's Avatar
Default Re: (vtecnitian)
Just call up RC or Siemen. They both have 1600cc injectors.
Old Jan 13, 2008 | 07:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnitian &raquo;</TD></TR><TR><TD CLASS="quote">iam planning 30-35psi or more on a 70mm turbo and don't want 85% duty cycle. all i want to know who makes them not y i want them lol.</TD></TR></TABLE>
OK cool guy. Let me know when you run 35lbs. You want a 700hp car but no nothing about building one. You cant even find injectors
Old Jan 13, 2008 | 11:49 AM
vtecnitian's Avatar
Default Re: (blkturbos2k)
Ok big guy if you say so. who i'am i to argue you might be right i don't care. i thought these forums where to help people out. but i guess not, i guess attitude is the way here. i didn't give you any attitude all i wanted was my question answered.Not everyone goes about building cars the same way i want 1600cc injectors to have a lil extra fuel to play around with. you have 1000cc and if it works for awesome thats not my set up . jackass. and i never said i wanted 700hp car just want 1600cc injectors if 700 happens good if it does good to. i do everything myself and like learning even if i'am wrong i don't pay shops to build my car.
Old Jan 13, 2008 | 11:59 AM
HondaKyle's Avatar
lol at this thread
Old Jan 13, 2008 | 01:28 PM
You said you were going to run 35+ psi on a 70mm turbo... What do you think you are going to make? 400hp?
[QUOTE= all i want to know who makes them not y i want them.[/QUOTE]
You kinda sound like a ***.
LET ME HELP YOU
http://WWW.GOOGLE.COM
Old Jan 13, 2008 | 01:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnitian &raquo;</TD></TR><TR><TD CLASS="quote">and i never said i wanted 700hp car just want 1600cc injectors if 700 happens good if it does good to. i do everything myself and like learning even if i'am wrong i don't pay shops to build my car.</TD></TR></TABLE>
So, you built your own turbo kit, built your own motor, tuned your own car, made your own brackets for a new diff, put a stronger trans in yourself, and you cant find god damn injectors
I assume you have a stronger diff and trans as EVERYONE that knows about the s2k knows it will need the diff and trans.
Please post pics of your car and your dyno sheet... when your done.
Im not trying to be a dick but between here and s2ki I see 2-3 people a week that are building a 700hp or 9sec s2k
Old Jan 13, 2008 | 02:21 PM
HondaKyle's Avatar
what is the trans good till... im just boosting 8 pounds so i should be fine right?
I dont beat on it or launch it....
Old Jan 13, 2008 | 10:05 PM
140sx's Avatar
walbro at the moment.... but just bought a aeromotive eliminator pump that is good to 1100 hp.. and the pump controllor to help it last. i think that im going to do a surge tank with mine as well. i have 1000cc injectors at the moment but im going to max them out in my new setup.
Old Jan 14, 2008 | 04:28 AM
Default Re: (140sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 140sx &raquo;</TD></TR><TR><TD CLASS="quote">walbro at the moment.... but just bought a aeromotive eliminator pump that is good to 1100 hp.. and the pump controllor to help it last. i think that im going to do a surge tank with mine as well. i have 1000cc injectors at the moment but im going to max them out in my new setup.</TD></TR></TABLE>
Thats funny, I talked to Peter @ ISP and he wants to do the same set up but we are going to run 2 255 pumps and a surge tank
Old Jan 20, 2008 | 09:03 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecnitian &raquo;</TD></TR><TR><TD CLASS="quote">Ok big guy if you say so. who i'am i to argue you might be right i don't care. i thought these forums where to help people out. but i guess not, i guess attitude is the way here. i didn't give you any attitude all i wanted was my question answered.Not everyone goes about building cars the same way i want 1600cc injectors to have a lil extra fuel to play around with. you have 1000cc and if it works for awesome thats not my set up . jackass. and i never said i wanted 700hp car just want 1600cc injectors if 700 happens good if it does good to. i do everything myself and like learning even if i'am wrong i don't pay shops to build my car.</TD></TR></TABLE>wow.. 1600cc is this going to be a dd street car? you can make 700whp on 1000cc injector with the right pump OR pumps so unless you need 1600cc why use them. you know you will have to run a injector driver also?
Old Jan 20, 2008 | 09:05 PM
HondaKyle's Avatar
Default Re: (1QwIkEf)
LMAO! 1qwikef you have the best icon
integrawow
Jun 15, 2009 07:43 PM
90civicgsr
Feb 7, 2008 06:17 AM
.BigSexy
Jun 20, 2007 07:11 PM
cambopheonix56
Apr 1, 2005 04:23 AM
