changed my oil after 6k miles...what could have happened??
had mobile 1 synthetic and a fram filter if you ask...but i was stupid to not pay attention cause i changed my oil at 211798 and checked where i wrote it and i thought i was supposed to change it at 217xxx...
...so i drove it normally till i saw those numbers and i finally noticed when i read over it right...soo anyways i noticed than it ran a little rough after my oil change...what can i have worn out or messed up not changing it at the appointed date?? juss curious
Did you check your oil regularly and make sure it was at the right level? I dont see anything bad hapening as long as you drove it normal and you kept the level where it was supposed to be.
6k on synthetic? You're fine. Honda's interval for regular oil is 7.5k, and synthetic will usually be okay beyond that, as it resists breakdown better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKstacy »</TD></TR><TR><TD CLASS="quote">Did you check your oil regularly and make sure it was at the right level? I dont see anything bad hapening as long as you drove it normal and you kept the level where it was supposed to be.</TD></TR></TABLE>
yea i was just about between the two holes on the dipstick when i changed it...ok makes me feel more relieved thank you guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia »</TD></TR><TR><TD CLASS="quote">
yea i was just about between the two holes on the dipstick when i changed it..</TD></TR></TABLE>
Yea, I usually try to keep mine at the top hole, but you should be good to go. So if its running rough i doubt its the oil.
