Do i have frame damage?
This is a really bad picture but it's the only one i have right now. Does the frame look a little bent?
A little higher where the radiator is and curves back where the ac is.
I would say yes. Look at where the bumper support lines up with the bottom of the radiator support. If you look closely enough, you can see that the far left hole on the top of the radiator support is closer to the bumper support (beam) than the hole on the far right.
Btw, I am hella tired so I may be wrong. Most likely am but w/e, at least I tried
supaman111
18
May 7, 2023 06:15 AM
jeffk182
23
Apr 27, 2005 01:07 PM
